I have a Zoneminder setup - tryin to merge it along with my MythTVsetup.
I have 2 IP gadget NC1000 cam up and running fine without any problem.
But I have also a USB cam from logitech:
Bus 003 Device 002: ID 046d:0840 Logitech, Inc. QuickCam Express
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.00
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 255 Vendor Specific Subclass
bDeviceProtocol 255 Vendor Specific Protocol
bMaxPacketSize0 8
idVendor 0x046d Logitech, Inc.
idProduct 0x0840 QuickCam Express
bcdDevice 1.00
iManufacturer 0
iProduct 1 Camera
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 55
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 1
Transfer Type Isochronous
Synch Type None
Usage Type Data
wMaxPacketSize 0x0000 1x 0 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x03ff 1x 1023 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 16
Device Status: 0x0001
Self Powered
Its just green image or white noise - so I think it something about the setup and settings for the CAM. Probing after the CAM cannot find it - But I've testet it in my laptop and runs fine there!
Device Path /dev/video0
Capture Method Video For Linux version 2
Enheds Kanal 0
Enheds Format PAL
Capture Palette JPEG
Capture Width (pixels) 320
Capture Height (pixels) 280
Preserve Aspect Ratio
Orientation Normal
TIA
Per
