im in serious trouble to install zone, i made like that:
apt-get -f install zoneminder...
then, in ZoneMinder-1.23.3 folder:
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin --with-webuser=www-data --with-webgroup=www-data --with-ffmpeg --with-libarch ZM_SSL_LIB=opensslNew
then:
make
then:
mysql mysql <db> grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass'
i tried give the sintax:
"mysql> quit"
but it refuses...
i tried quit;
was refused too, so:
ctrl+c
the make install
and when i try
andre:/home/dukenukem# /etc/init.d/zoneminder start
Starting ZoneMinder: DBD::mysql::st execute failed: SELECT command denied to user 'zmuser'@'localhost' for table 'Config' at /usr/local/share/perl/5.10.1/ZoneMinder/Config.pm line 92.
Can't execute: SELECT command denied to user 'zmuser'@'localhost' for table 'Config' at /usr/local/share/perl/5.10.1/ZoneMinder/Config.pm line 100
BEGIN failed--compilation aborted at /usr/local/share/perl/5.10.1/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/local/share/perl/5.10.1/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/local/share/perl/5.10.1/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 45.
failure
some clue?
________
VERMONT DISPENSARY
how to solve it?
how to solve it?
Last edited by DRAGSTER_TUNER on Sat Feb 12, 2011 2:55 pm, edited 1 time in total.
Re: how to solve it?
The mysql user you are using does not have the privileges to select, and probably create the database structure.
Install phpmyadmin, or research mysql users. Remember to flush privileges when you are done.
i installed phpmyadmin nothing changes:
andre:/home/dukenukem/arquivos/ZoneMinder-1.23.3# /etc/init.d/zoneminder startStarting ZoneMinder: Warning, overriding installed ./zm.conf file with local copy
failure
Sorry, im noob, how i research mysql users and flush privileges?
________
Medical Marijuana Card
failure
________
the problem is i tried install it by /.configure make make install on zoneminder 1.23 too
i already give an make uninstall on 1.23 folder and apt-get --purge remove zoneminder...
and then apt-get -f install zoneminder...
but the error keeps...some clue?
INSTEAD, have some way to i use my zoneminder i have (working) in my other hard disc?
i tried chroot /media/sdb1
and then:
andre:/# /etc/init.d/zoneminder start
Starting ZoneMinder: DBI connect('database=zm;host=localhost','zmuser',...) failed: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) at /usr/share/perl5/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/share/perl5/ZoneMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33.
failure
have some way to use my old hd?
________
YAMAHA VENTURE SPECIFICATIONS
and then:
failure
________
Last edited by DRAGSTER_TUNER on Tue Mar 08, 2011 8:30 am, edited 1 time in total.
Last edited by DRAGSTER_TUNER on Sat Feb 12, 2011 2:56 pm, edited 1 time in total.
Indeed...thanks!
Since i made the correct syntax i installed it (now instead using 1.24).
________
Plymouth superbird
________
Plymouth superbird
