Running ZM along with virtual hosts
SquALeD
Post by SquALeD »
Hi all,
Thanks for a great prog!
Got ZM working fine under Ubuntu 9.04 desktop a while ago using the modification to the /etc/apache2/sites-enabled/000-default file to make ZM the primary host in apache.
A while after this I had to delete ZM for various reasons and in the meantime I have set up a website running off the 'default' host on port 80.
Tried to set up ZM again today and although it has an entry in mysql as seen through webmin there doesn't seem to be any virtual server set up for it although it has written the /usr/share/zoneminder files.
So when I try to access localhost/zm I get a 404 page not found error
How can I set up a working virtual server for zm?
Hope this makes sense people as Im pretty new to Ubuntu
Cheers, Sq
SquALeD
Post by SquALeD »
noone?
kingofkya
Post by kingofkya »
ok to make it easy
sudo apt-get remove --purge apache2
sudo apt-get remove --purge zoneminder
sudo apt-get install apache2
sudo apt-get install zoneminder
That should get you back
