Grouping
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
scriptman78
Grouping
Post by scriptman78 »
Here is my Wish List for the next release:
1. A way to set the Default Group from No Group to one of the custom groups
2. The ability to compact the montage, set the number of columns, and set the size in Options->Web the way you could in 1.23.3
3. The ability to select groups while in montage for on the fly monitoring
