no fps state when browsing the cam
antar
Post by antar »
there is no fps state when browsing the cam
using a trendnet IP cam. how do i fix that?
ZM working ok and detecting events.
bump
antar
Post by antar »
any help on this?
pki
Post by pki »
Tell us more, which system, which ZM version, the config of the cam in ZM and do other cams on you zoneminder shows fps?
SQ2LYH :-)
antar
Post by antar »
pki wrote:Tell us more, which system, which ZM version, the config of the cam in ZM and do other cams on you zoneminder shows fps?
using ZM 1.24 om mandriva 2010
cambozla and ffmpeg installed
only one camera Trendnet IP201 with pic at 192.168.1.9/image.JPG
Remote Protocol HTTP
Remote Method Simple
Remote Host Name 192.168.1.9
Remote Host Port 5000
i can see the picture, detection works ok.
using web http 1.1
antar
bump
Post by antar »
bump
kingofkya
Post by kingofkya »
do you have zm running in mpeg or jpeg mode?
jpeg is the only mode that showes fps.
antar
using jpeg to stream to the browser
Post by antar »
i do not show the state either
Xploder
Post by Xploder »
Here are my settings for the Trendnet TVIP110 &110W:
i get ~25fps with these settings.
Only the relevant info is shown:::
General Tab
Source Type: Remote
Maximum FPS:30.00
Reference Image Blend %ge: 7
Source Tab:
Remote Protocol	: HTTP
Remote Method: Simple
Remote Host Name: uname:pass@192.168.16.XXX
Remote Host Port: 80
Remote Image Colors	: 24 Bit Colors
Capture Width (pixels):640
Capture Height (pixels):480
Hope these settings Help
X
timcraig
Post by timcraig »
I had a problem on Arch Linux/Zoneminder box where I couldn't see the fps. I had to enable PHP's sockets extension to get the fps indicator to work.
I had to uncomment the following line in my /etc/php/php.ini:
extension=sockets.so
Distributions may vary.
antar
Post by antar »
timcraig wrote:I had a problem on Arch Linux/Zoneminder box where I couldn't see the fps. I had to enable PHP's sockets extension to get the fps indicator to work.
Tried this in php.ini with no luck.
i also looked in etc/php.d where the extension modules are in mandriva 2010
