ffmpeg monitor zmc and cpu load
dariush
Post by dariush »
I've configured a monitor with ffmpeg to stream a vlc screencast.
The streaming works fine in normal conditions.
Stopping the vlc streaming the zmc process related that monitor starts consuming cpu (90%) untile zm is restarted or that monitor is switched on 'none' (that means the related zmc process is killed).
Launching mmpeg on the same stream by command line works perfectly, once the streaming is stopped ffmpeg stops too.
I've tested also another type of monitor, configured as remote and connected to a axis camera, in that case if the camera is powered off everything continue to work fine and I don't have any kind of overload from the zmc process related to the monitor.
Any suggestion?
Thank you,
Dariush.
