I'm having trouble getting this camera working with ZM. The camera has a JPEG image available at http://192.168.1.122/loginfree.jpg which shows up fine in Firefox but when I put this in as a remote cam in ZM it stays red and only shows a black image. In the 'source' tab I have the following settings:
protocol: HTTP
method: simple
host name: 192.168.1.122
host port: 80
host path: /loginfree.jpg
host subpath:
image colors: 24 bit color
capture width: 640
capture height: 640
preserve aspect ratio: unchecked
orientation: normal
I understand that ZM supports single JPEG cameras - is there something I'm doing wrong?
Hawking HNC290G
In the web server of the camera you have to enable the loginfree.jpg or you can use "/jpg/image.jpg" and username:password@cameraip
This camera is sold under a bunch of names check this site out. Yours might not look like the one on the front page but it is probably the same.
http://ic1500.wikispaces.com/
be sure to check the html hack on that site if you plan to use that camera outside.
