I am in the process of adding IP cameras throughout my house. While they will be several different makes / models, the one I have in hand at this time is a Panasonic BL-C131A.
I am attempting to use this cam with ZM 1.24.2 on an Ubuntu 9.10 server. The ZM install went well for the most part and the ZM console seems to be running properly.
I tried several different methods of adding the Panasonic cam without success. This includes probing the camera, which resulted in error 127. The most progress I've made so far is trying the preset "Panasonic IP PTZ, 640x480, jpeg". When I open the monitor after assigning ip/port values to the preset, I am rewarded with a snapshot of the cam (which I neglected to mention is working fine under its stock webpage). The issue is, after about 3-4 seconds the image disappears and changes to the "Broken Image" icon.
I have searched the forum and have been unable to find an error similar to mine (not to say it doesn't exist). I am open to any suggestions.
Thanks!
Panasonic BL-C131A ZM Setup Issue
The camera itself is functioning properly and as such, has an empty error log. It does show a number of successful connections, however does not elaborate beyond that.
As far as ZM goes:
zmaudit.log = emtpy
zmdc.log =
zmfilter.log =
zmpkg.log =
zmwatch.log =
Thanks,
cc
As far as ZM goes:
zmaudit.log = emtpy
zmdc.log =
03/21/10 21:21:58.933920 zmdc[2001].INF [Server starting at 10/03/21 21:21:58]
03/21/10 21:22:02.011147 zmdc[2001].INF ['zmc -m 2' starting at 10/03/21 21:22:02, pid = 2048]
03/21/10 21:22:02.090807 zmdc[2001].INF ['zmfilter.pl' starting at 10/03/21 21:22:02, pid = 2051]
03/21/10 21:22:02.169789 zmdc[2001].INF ['zmaudit.pl -c' starting at 10/03/21 21:22:02, pid = 2054]
03/21/10 21:22:02.264759 zmdc[2001].INF ['zmwatch.pl' starting at 10/03/21 21:22:02, pid = 2056]
03/21/10 21:22:02.341732 zmdc[2001].INF ['zmupdate.pl -c' starting at 10/03/21 21:22:02, pid = 2060]
03/21/10 21:22:02.216680 zmfilter[2051].INF [Scanning for events]
03/21/10 21:21:58.729360 zmpkg[1951].INF [Command: start]
03/21/10 21:22:05.064512 zmpkg[2482].INF [Command: start]
03/21/10 21:22:02.336055 zmwatch[2056].INF [Watchdog starting]
03/21/10 21:22:02.336212 zmwatch[2056].INF [Watchdog pausing for 30 seconds]
cc
guess the cam is somehow similar to the BLC1, look at my post at
http://www.zoneminder.com/forums/viewtopic.php?t=15406
also check your shared memory settings - typically if the allocated memory is too small it works for a few seconds till the mem is full and then malfunctions - sometimes even without a useful error message
you'll see that there are many posts about the memory issues
