Can't compile with uclibc (exeinfo.h missing)
lapacho
Post by lapacho »
Is it safe to disable all the backtrace code from zoneminder just to compile it with an uclibc toolchain?
That's the only problem that seems I'm facing. I have solved the others installing the correspondent dependency.
Any ideas? I disable debug, crashtrace, etc but zm stills want to compile backtraces. (zm_signal.h and zm_signal.cpp).
Regards,
lapacho
Post by lapacho »
any ideas on this? Is it posible to compile zm without backtrace support?
regards,
