Function ereg() is deprecated
DREMA
Post by DREMA »
I keep geting lots of this errors in my httpd/error_log
[Fri Nov 13 10:53:35 2009] [error] [client 189.145.xxx.xxx] PHP Deprecated: Function ereg() is deprecated in /var/lib/zm/www/includes/functions.php on line 808, referer: http://xxx.xxx.org/zm/index.php
[Fri Nov 13 10:53:35 2009] [error] [client 189.145.xxx.xxx] PHP Deprecated: Function ereg() is deprecated in /var/lib/zm/www/includes/functions.php on line 813, referer: http://xxx.xxx.org/zm/index.php
How can I solve this? I'm using
- Zoneminder-svn
- PHP 5.3.0-5
- apache 2.2.14-2
kingofkya
Post by kingofkya »
hope fulll this will be fixed before php 6 comes out anyways
open up php.ini and comment out the sections on errors
use ;
jcpu
Re: Function ereg() is deprecated
Post by jcpu »
DREMA wrote:I keep geting lots of this errors in my httpd/error_log
- Zoneminder-svn
- PHP 5.3.0-5
- apache 2.2.14-2
Change section in functions.php (ZM Version 1.24.2 ) to:
    if (preg_match( '/MSIE ([0-9].[0-9]{1,2})/',$_SERVER['HTTP_USER_AGENT'],$logVersion))
        $version = $logVersion[1];
        $browser = 'ie';
    elseif (preg_match( '#Safari/([0-9.]+)#',$_SERVER['HTTP_USER_AGENT'],$logVersion))
        $browser = 'safari';
        elseif (preg_match( '#Konqueror/([0-9.]+)#',$_SERVER['HTTP_USER_AGENT'],$logVersion))
                $browser = 'konqueror';
    elseif (preg_match( '/Opera ([0-9].[0-9]{1,2})/',$_SERVER['HTTP_USER_AGENT'],$logVersion))
        $browser = 'opera';
    elseif (preg_match( '#Mozilla/([0-9].[0-9]{1,2})#',$_SERVER['HTTP_USER_AGENT'],$logVersion))
        $browser = 'mozilla';
    else
        $version = 0;
        $browser = 'unknown';
mastertheknife
Post by mastertheknife »
Thank you jcpu, i added it to to a page i just made to centralize all bug fixes:
http://www.zoneminder.com/wiki/index.ph ... 2_Bugfixes
Sir Veillance
Post by Sir Veillance »
kingofkya wrote:open up php.ini and comment out the sections on errors
this would affect all php programs running on the server (unless you copy the php.ini into your zm directory and manipulated that one)
What one should do is
  • grep error_reporting *.php
    change all occurrences to error_reporting(E_ALL ^ (E_NOTICE | E_DEPRECATED));
The most important change is in index.php
If you want to keep E_NOTICE, use error_reporting(E_ALL ^ E_DEPRECATED);
Martin from Germany
