2 x PV-981a-16 hardware setup
geekspeed
Post by geekspeed »
New to ZM - just got 2 PV-981a-16 cards from bluecherry. The box is fresh CentOS 5.4 x86_64 build.
I am trying to figure out how to get these cards setup in zm. From what I have been reading -- for a 2 card 32 channel setup -- I should have video0 through video15. With 2 channels per video device. Currently I have video0 through video7 with 2 channels. Is there any way to get the other card to get recognized?
Any help would be apprecaited.
lspci:
02:00.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:00.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
02:01.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:01.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
02:02.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:02.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
02:03.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:03.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
03:00.0 PCI bridge: Texas Instruments XIO2000(A)/XIO2200(A) PCI Express-to-PCI Bridge (rev 03)
04:00.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:00.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
04:01.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:01.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
04:02.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:02.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
04:03.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
04:03.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
lsmod:
bttv 232885 0
video_buf 59461 1 bttv
ir_common 63173 1 bttv
compat_ioctl32 41793 1 bttv
i2c_algo_bit 42185 1 bttv
btcx_risc 37961 1 bttv
tveeprom 49617 1 bttv
i2c_core 56129 4 i2c_ec,bttv,i2c_algo_bit,tveeprom
videodev 58688 1 bttv
v4l2_common 57153 3 bttv,compat_ioctl32,videodev
zmu:
zmu -d /dev/video0 -q -v -a
Error, failed to query crop capabilities /dev/video0: Invalid argument
zmu -d /dev/video0 -V1 -q -v -a
Video Device: /dev/video0
Video Capabilities
Name: BT878 video (ProVideo PV150)
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 2
Audio Channels: 0
Maximum Width: 640
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 1 - Linear greyscale
Colour Depth: 8
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
ls -al /dev/vid*
lrwxrwxrwx 1 root root 6 Apr 1 07:17 /dev/video -> video0
crw----rw- 1 root root 81, 0 Apr 1 07:17 /dev/video0
crw------- 1 root root 81, 1 Apr 1 07:17 /dev/video1
crw------- 1 root root 81, 2 Apr 1 07:17 /dev/video2
crw------- 1 root root 81, 3 Apr 1 07:17 /dev/video3
crw------- 1 root root 81, 4 Apr 1 07:17 /dev/video4
crw------- 1 root root 81, 5 Apr 1 07:17 /dev/video5
crw------- 1 root root 81, 6 Apr 1 07:17 /dev/video6
crw------- 1 root root 81, 7 Apr 1 07:17 /dev/video7
modprobe:
options bttv card=98,98,98,98,98,98,98,98,98,98,98,98,98,98,98,98
dmesg:
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:02:00.0, irq: 169, latency: 32, mmio: 0xd80f8000
bttv0: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
bttv0: using: ProVideo PV150 [card=98,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 ..........failed
bttv: Bt8xx card found (1).
bttv1: Bt878 (rev 17) at 0000:02:01.0, irq: 177, latency: 32, mmio: 0xd80fa000
bttv1: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
bttv1: using: ProVideo PV150 [card=98,insmod option]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: using tuner=-1
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (2).
bttv2: Bt878 (rev 17) at 0000:02:02.0, irq: 58, latency: 32, mmio: 0xd80fc000
bttv2: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
bttv2: using: ProVideo PV150 [card=98,insmod option]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: using tuner=-1
bttv2: i2c: checking for TDA9875 @ 0xb0... not found
bttv2: i2c: checking for TDA7432 @ 0x8a... not found
bttv2: i2c: checking for TDA9887 @ 0x86... not found
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (3).
bttv3: Bt878 (rev 17) at 0000:02:03.0, irq: 66, latency: 32, mmio: 0xd80fe000
bttv3: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
bttv3: using: ProVideo PV150 [card=98,insmod option]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: using tuner=-1
bttv3: i2c: checking for TDA9875 @ 0xb0... not found
bttv3: i2c: checking for TDA7432 @ 0x8a... not found
bttv3: i2c: checking for TDA9887 @ 0x86... not found
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (4).
bttv4: Bt878 (rev 17) at 0000:04:00.0, irq: 169, latency: 32, mmio: 0xd81f8000
bttv4: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
bttv4: using: ProVideo PV150 [card=98,insmod option]
bttv4: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv4: using tuner=-1
bttv4: i2c: checking for TDA9875 @ 0xb0... not found
bttv4: i2c: checking for TDA7432 @ 0x8a... not found
bttv4: i2c: checking for TDA9887 @ 0x86... not found
bttv4: registered device video4
bttv4: registered device vbi4
bttv4: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (5).
bttv5: Bt878 (rev 17) at 0000:04:01.0, irq: 177, latency: 32, mmio: 0xd81fa000
bttv5: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
bttv5: using: ProVideo PV150 [card=98,insmod option]
bttv5: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv5: using tuner=-1
bttv5: i2c: checking for TDA9875 @ 0xb0... not found
bttv5: i2c: checking for TDA7432 @ 0x8a... not found
bttv5: i2c: checking for TDA9887 @ 0x86... not found
bttv5: registered device video5
bttv5: registered device vbi5
bttv5: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (6).
bttv6: Bt878 (rev 17) at 0000:04:02.0, irq: 58, latency: 32, mmio: 0xd81fc000
bttv6: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
bttv6: using: ProVideo PV150 [card=98,insmod option]
bttv6: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv6: using tuner=-1
bttv6: i2c: checking for TDA9875 @ 0xb0... not found
bttv6: i2c: checking for TDA7432 @ 0x8a... not found
bttv6: i2c: checking for TDA9887 @ 0x86... not found
bttv6: registered device video6
bttv6: registered device vbi6
bttv6: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (7).
bttv7: Bt878 (rev 17) at 0000:04:03.0, irq: 66, latency: 32, mmio: 0xd81fe000
bttv7: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
bttv7: using: ProVideo PV150 [card=98,insmod option]
bttv7: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv7: using tuner=-1
bttv7: i2c: checking for TDA9875 @ 0xb0... not found
bttv7: i2c: checking for TDA7432 @ 0x8a... not found
bttv7: i2c: checking for TDA9887 @ 0x86... not found
bttv7: registered device video7
bttv7: registered device vbi7
bttv7: PLL: 28636363 => 35468950 .. ok
bttv0: PLL can sleep, using XTAL (28636363).
uname -a:
Linux box.localhost 2.6.18-164.15.1.el5 #1 SMP Wed Mar 17 11:30:06 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux
kingofkya
Post by kingofkya »
this is not the stuff for you card but simmler if your modprobe file is setup for a 4 cam 2 chip card card=77,77 tuner=4,4
now for 2 of the the same cards card=77,77,77,77 tuner=4,4,4,4
so basically whatever you have in there double it for the second card.
