I have noticed that the "Alarm" status doesn't show up any more and the most I get is alert.
Two things had changed at the time this started.
I changed from RH9 to FC2 (same result with FC3)
and changed from ZM-1.19.4 to ZM-1.19.5
The result is the sound files don't play since I never achive an alarm status.
Anyone else noticed the same? I am wondering if maybe the Alarm Frame count change might have something to do with it.
I'm just more curious than anything else.
Cheers,
Cordel
update:
I take that back. occasionaly I'll get the alarm. It seems that the status window has to refresh at just the correct time and the alarm status gets passed by a majoriity of the time (at least with the settings I have).
Status window and alarm levels
- zoneminder
- Site Admin
- Contact:
