FPS Not right?
jayman
FPS Not right?
Post by jayman »
I just installed ZM today with a Pico2000 card. From what I read it should give me 5fps per port. Right now ZM is only showing 1.27 per port with all 4 in use. I have a 2nd card which 1 port is in use and it's only showing 5.5FPS.
Is there something I need to adjust to at least get it upto 5fps.
whatboy
Post by whatboy »
Where did you read that??? in a seller/maker pamflet??? yeah right... 1.27 is quite right... when I has a one chip 4 channels, I only used 2 channels per card, installed 2 cards so I had 4 cameras @ 4.5fps...
Now there you have a problem... it should be 30fps... maybe you're value is too high on OPTIONS -> CONFIG -> CAPTURES_PER_FRAME, what value do you have there???
kingofkya
Post by kingofkya »
I agree what your getting about right. Switching takes a lot of time.basicly it about a exponentially 1/3 of fps loss everytime you add a cam so.
1 cam 30FPS
2 cams 10fps each
3cams 3fps each
4cams 1fps each
jayman
Post by jayman »
I have 2 in there as the option.
These cards were in our old DVR from Chubb Security with the Netvision software. When running them in windows with that software it was putting out alot more then 1.27fps. For both displaying and recording video.
Why can windows do it and linux not do it?
jayman
Post by jayman »
For the poster who asked where I seen that each should get at least 5fps
http://www.camsecure.co.uk/Zoneminder.html which is listed in the shop link at the top.
First card on the page is the exact same one I have.
This means that if you are using all 4 inputs you will have a maximum of 6
frames per second per camera which is often adequate for many applications.
kingofkya
Post by kingofkya »
Honestly thats imposable its a hard where limitation.
also yes technical you can get 6fps but they will be interlaced with the previous camera. turn of v4l_multibuffer to see what I mean.
Now what it could have been doing is showing you a live feed for 3 seconds at 5 fps or more and then moving the the next one so it appeared to be capturing faster. Rather that what zm does which is switch between every frame.
