hiya
i can access one time then my ip changes
what trick can i use to keep my ip static from the inside
iv got win and linux machines
some little wiget to run in the background to keep my ip from changing
i have tryed "keep my ip.exe" in one of my win machines dont work
ip changes after each outside connection to ZM
isp=dslextreme
any ideas or help greatly appreciated
jeff
dynamic ip only static not available in my area
There's also http://www.dyndns.com/ uses ddclient to update...
First of all I'll suggest you to check if your router (if you got one) support dynamic dns, if so will show a list of supported services (dyndns is very common).
Create an account with the service you choose and setup your router.
Setting up the router have many pros but the most important one is that updates will be done as soon your external ip changes even if your PCs are switched off.
my 2 cents
my 2 cents
ddns and dynamic ip, static not available
hiya
so my router supports 2 ddns services both are pay type
i know of a free ddns service i found where i create a subdomain
like jefflarson.afraid.org with afraid is a domain name they own
and run a ddns updater app in one of my comps
this is " http://freedns.afraid.org/ "
im just haveing some trouble setting it up
i was hopeing there was a sneekey little app that would trick there
dynamic ip into thinking there was a internal computer transmitting data constantly maybe like a outgoing endless email "one byte" transmitted at
the max keepalive for the connection "as not to gobble up my bandwith" and ..........thats a theroy based on the assumption that the dynamic ip won't change during a transmit session from my end
is my asumption about outgoing traffic keeping the ip from changing during a transmit session correct ?
anything like that out there ?
jeff
jeff
