My card is a Conexant 878A, Sony camera is 420 lines maximum resolution of 512x582 is four cameras for the other is 500x582, OpenSUSE system, 4GB of RAM ...
Four cameras are working correctly at a resolution of 384x288 but not at higher.
(Video0, video4, video6, video7)
Four cameras are working at 320x240 resolution but with higher not work.
(VIDEO2, video1, video3, video5)
When a higher resolution than I gave above and white image error in the logs.
[Sat Apr 17 19:19:42 2010] [error] [client 80.xx.xxx.x] socket_sendto( /tmp/zms-983573s.sock ) failed: No such file or directory, referer: http://79.xxx.xx.xx/zm/index.php?view=watch&mid=1
[Sat Apr 17 19:19:42 2010] [error] [client 80.xx.xxx.x] array (\n 0 => \n array (\n 'file' => '/srv/www/htdocs/zm/ajax/stream.php',\n 'line' => 51,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-983573s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/srv/www/htdocs/zm/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/srv/www/htdocs/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://xx.xxx.xx.xx/zm/index.php?view=watch&mid=1
on montage:
Apr 17 19:50:53 t1 zms[15169]: ERR [Signal address is 0x206, no eip]
Apr 17 19:50:53 t1 zms[15169]: ERR [Backtrace: /lib64/libpthread.so.0 [0x7f9429d86a90]]
Apr 17 19:50:53 t1 zms[15169]: ERR [Backtrace: /lib64/libc.so.6(gsignal+0x35) [0x7f9428c99645]]
Apr 17 19:50:53 t1 zms[15169]: ERR [Backtrace: /lib64/libc.so.6(abort+0x183) [0x7f9428c9ac33]]
Apr 17 19:50:53 t1 zms[15169]: ERR [Backtrace: /srv/www/cgi-bin/nph-zms [0x40f1cb]]
Apr 17 19:50:53 t1 zms[15169]: ERR [Backtrace: /srv/www/cgi-bin/nph-zms [0x42d799]]
Apr 17 19:50:53 t1 zms[15169]: ERR [Backtrace: /srv/www/cgi-bin/nph-zms [0x4230ef]]
Apr 17 19:50:53 t1 zms[15169]: ERR [Backtrace: /srv/www/cgi-bin/nph-zms [0x423b3d]]
Apr 17 19:50:53 t1 zms[15169]: ERR [Backtrace: /srv/www/cgi-bin/nph-zms [0x406b8f]]
Apr 17 19:50:53 t1 zms[15169]: ERR [Backtrace: /lib64/libc.so.6(__libc_start_main+0xe6) [0x7f9428c85586]]
Apr 17 19:50:53 t1 zms[15169]: ERR [Backtrace: /srv/www/cgi-bin/nph-zms [0x406339]]
Apr 17 19:50:53 t1 zms[15169]: INF [Backtrace complete]
When the transmission method is a jpeg everything works correctly at a resolution of 384x288 with a higher I do not know why the effect of horizontal lines when the object in motion.
http://en.wikipedia.org/wiki/Interlace
pls help
