I've checked the logs and im getting....
04/19/10 20:32:57.888601 zmpkg[1342].INF [Command: start]
04/19/10 20:32:59.240521 zmpkg[1342].ERR [Unable to run "sudo -u www-data /usr/local/bin/zmfix", output is ""]
04/19/10 20:38:49.346766 zmpkg[1687].INF [Command: start]
04/19/10 20:38:49.896888 zmpkg[1687].ERR [Unable to run "/usr/local/bin/zmfix", output is ""]
Am I right in thinking this may be related to a user permission issue?
Just in case its related, I installed Mplayer and mencoder, then removed them..
UPDATE : When trying to restart zoneminder with the command "sudo service zm restart" I get the following.....
Stopping ZoneMinder: failure
Starting ZoneMinder: /usr/local/bin/zmfix: /usr/lib/i686/cmov/libavformat.so.52: no version information available (required by /usr/local/lib/libavdevice.so.52)
/usr/local/bin/zmfix: /usr/lib/i686/cmov/libavcodec.so.52: no version information available (required by /usr/local/lib/libavdevice.so.52)
/usr/local/bin/zmfix: relocation error: /usr/local/lib/libavdevice.so.52: symbol av_free_packet, version LIBAVCODEC_52 not defined in file libavcodec.so.52 with link time reference
failure
