1.24.3 Hangs system
sashcomua
1.24.3 Hangs system
Post by sashcomua »
Established openSUSE 11.2, capture cards Kodicom 4400r, Intell Celeron Dual Core 2,5, 2Gb RAM
The CPU usage is almost always reaches 50-90%, after a while very little RAM (10-15Mb), and very often the system crashes.
In a single logs errors and problems were found, neither in the system neither in the Zo
neminder
Tell me which may be related to this problem.......
sashcomua
Post by sashcomua »
Version 1.24.2, not attentive.
I can not find where to set the number of frames to write to modect, tell me please
sashcomua
Post by sashcomua »
Although everything is normal, the cause was found - the motherboard. Although there is another bottleneck - but I doubt that, it is this http://xmages.net/upload/446d3687.jpg ;)
