Shell Script: creating one video file per day
beerygaz
Post by beerygaz »
My events structure doesn't look like yours suggests.
I have ./events/<monitorID>/<5> like this:
/var/lib/zoneminder/events/19/89799
ls -la in Monitor ID 19 folder reveals:
drwxr-xr-x    2 apache apache 12288 2010-02-28 10:23 89786
drwxr-xr-x    2 apache apache 20480 2010-02-28 11:02 89789
drwxr-xr-x    2 apache apache 12288 2010-02-28 11:55 89790
drwxr-xr-x    2 apache apache 12288 2010-02-28 12:59 89793
drwxr-xr-x    2 apache apache 12288 2010-02-28 13:02 89795
drwxr-xr-x    2 apache apache  4096 2010-02-28 17:54 89797
drwxr-xr-x    2 apache apache 20480 2010-03-01 06:11 89799
Any idea why my events folders are these numbers and not named by date?
Version: ZM 1.24.1
Flav
Post by Flav »
beerygaz wrote:My events structure doesn't look like yours suggests.
Version: ZM 1.24.1
This is the good structure the script find the events Creat at this Date
whatboy
Post by whatboy »
You're not using Options -> Paths -> USE_DEEP_STORAGE on to store events...
beerygaz
Post by beerygaz »
Flav / whatboy - seem to be conflicting answers. Do I keep the existing structure and look for some other problem? Or do I need to enable USE_DEEP_STORAGE?
Flav
Post by Flav »
i'm not use : USE_DEEP_STORAGE and it's work.
coke
Post by coke »
Deep storage also increases the speed of deletes, eliminates possible file limit problems down the road, and probably a few other things that are handy.
whatboy
Post by whatboy »
I only have a problem, I created a script with my solution, to added to the crontab... script (zmmkmov) looks like...
#!/bin/sh
rm /home/user/bin/list.txt
ls -Ca --format=single-column /events/1/$(TZ=EST24EDT date +%y/%m/%d)/.*/*capture.jpg > /home/user/bin/list.txt
/usr/bin/mencoder "mf://@list.txt" -mf fps=5 -o /home/user/bin/mon1-$(TZ=EST26EDT date +%F).avi -ovc lavc -lavcopts vcodec=mpeg4
sudo mv /home/user/bin/mon1-$(TZ=EST26EDT date +%F).avi /stuffs/video
and on crontab I set to ran at 00:10 each day, but emncoder exit with error, I don't have the e-mail that shows the error, but I'll post it here later, and I can't use SUDO on a crontab??? gives me an error too
SHELL=/bin/sh
HOME=/home/user
PATH=/usr/bin:/bin:/home/user/bin
LOGNAME=user
USER=user
10 00 * * * umask 002; /home/user/bin/zmmkmov
Maybe is the "mf://@list.txt" I'll try with "mf://@/home/user/bin/list.txt" and see if mencoder doesnt fail, but sudo??? why can I use sudo on a crontab??? it says I can only use sudo on a tty console...
But if I ran it manual from console, nor mencoder, nor sudo (ofcourse) gives me errors!!!
kongobongo
Post by kongobongo »
I've created the script from the first post and customised it with the correct options, when I run it I get the following output....
Found ZM Events Directory: /var/www/zm/events/ -> OK!
Found Video Output Directory: /var/www -> OK!
Found Monitor: 10 -> OK!
Found requested day: 2010-04-19 -> OK!
Found FFmpeg binary: /usr/local/bin/ffmpeg -> OK!
Processing wanted events......23431 events found
Building video: /var/www/2010-04-19--Monitor-10.avi -> FINISHED!
Removing temporary files, bye!
The amount of events is incorrect, I only have a total of 1375 events combined for both cameras. The output video file is only 1mb in size.
Any suggestions as to where I am going wrong?
brunitho
Post by brunitho »
I'm having problems with the line 73 states:
argument list too long
has some way to improve this line or reduce the amount of arguments?
kongobongo
Yep, i'm getting that argument error as well now.....
The script looks like a good starting point, just needs looking at. I've tried to get in touch with Trendkill via email and msn but with no joy :(
johnnytolengo
crontab
Post by johnnytolengo »
whatboy be careful with the crontab expressions, try with this:
as a root
10 0 * * * root /home/user/bin/zmmkmov
as apache
10 0 * * * www-data /home/user/bin/zmmkmov
good luck.
Tolengo.
brunitho
Post by brunitho »
what a pity
my zoneminder is not willing to export the videos is still saying, exporting and not displayed the files to download.
look
http://www.zoneminder.com/forums/viewto ... highlight=
and my HD is getting full.
kongobongo
I am speaking to TrendKill, the original author about the problems so I will post an update as soon as I have one
lifeisboost
Post by lifeisboost »
Hello everyone.
I am trying to use this script but it never finds my events. i manually tried running the command
[root@localhost zm]# ls -Al /var/www/html/zm/events/1/ --time-style=long-iso |grep -l 2010-05-01
to try and find the events but this is the response it returns. im not sure where to go as i have not found any answers in looking through the net on the response.
(standard input)
