The monitors not showing seems to be due to the zmBandwidth cookie not being set; I've made a change to fallback to the way low and medium bandwidth modes are working in the even that the cookie is not set. Working in FF for Windows and Linux and IE8 for Windows.thomasjohansen wrote:Version 1.24.1 (ubuntu) Victor peterson livecd
windows 7 Firefox 3.6.3
Axis IP M3014 1280x800
Tried both with and without user auth and with plain and hash and none.
classic skin works fine.
New Skin for 1.24
download
Is it there a download link to share it with us?
regards
regards
What I recommend doing is using git so that you can stay with the latest changes - from the first post of this topic:
Remember that this is still a work in progress so there will be bugs, missing features, etc. Please give FEEDBACK.I am working on a new skin for 1.24. Instead of manually taring up the skin every time I make changes, I am going to use git. So, if you want to try out the skin, you'll need to change into your zm/skins/ directory and checkout my git repo which can be accessed at git://github.com/kylejohnson/zm_newskin.git.
I have my zoneminder configured as a virtual host mounted on /zoneminder and it seems like all the links to
* Cameras
* Events
* Timeline
* Admin.
* Options
* System
are pointing out of the virtual host mount point.
Relevant Apache config:
<Directory "/var/www/zoneminder/cgi-bin">
</Directory>
Alias /zoneminder "/var/www/zoneminder/htdocs"
<Directory "/var/www/zoneminder/htdocs">
</Directory>
* Cameras
* Events
* Timeline
* Admin.
* Options
* System
</Directory>
</Directory>
Is it mentioned anywhere that the skin directory has to be named "new" for it to work? I got a lot of error messages about "File does not exist: /var/www/zoneminder/htdocs/skins/new" when the directory was called "zm_newskin".
About the virtual host issue, I get a lot of
"File does not exist: /var/www/localhost/htdocs/skins, referer: http://oberg.homedns.org/zoneminder/index.php" when using the new skin. I think that there probably are some references to skin files that should be changed to. I'll try to figure these out and post a patch or something (should be 6 of them).
oberg: Indeed the directory name does have to be 'new'. I named my git repo 'zm_newskin' without realizing that this would require another manual step (mv zm_newskin new).
As for the broken links, a lot of the paths are coded like '/skins/new/' instead of 'skins/new/'. This should be an easy enough fix and I should be able to commit something today.
I will also look into renaming my repo (or the paths) to make this easier.
Quick update
Just to keep you all informed on some of the recent updates:
1: I wasn't able to get zms working on my system for viewing events (even with the default skin), so I am directly streaming the recorded jpg files from the disk. The downside of this is the possibly large preload time. The upside of this is very fine-tuned control over playback functions (to the frame). Still being worked on, but functional.
2: Substituted most / all popups with lightboxes, such as for the live view, and viewing of events.
3: Easy "export" button when viewing an event. Click "export" button, file is generated in background, and then made available to you. Can be done while video is playing back.
4: Grouped monitors and events together (respectively) for easier navigation from one to the next
And those are the major ones that I can remember for now.
Check out the git repo (ask if you need help) and give me some feedback!
I did like this :lookathome wrote:Hi,
when i try to add new monitor in the admin section i recive this error :
Fatal error: Call to undefined function getTableAutoInc() in /usr/share/zoneminder/skins/new/views/monitor.php on line 51
git clone git://github.com/kylejohnson/zm_newskin.git
copy/pasted into zoneminder skin
renamed zm_newskin folder in new
same problem....
great skin in anycase!
Shouldn't be happening... Are you navigating to the correct skin by going to http://you.zm.host/?skin=new ?lookathome wrote:I did like this :lookathome wrote:Hi,
same problem....
Try deleting the entire new skin directory before cloning it again, just to be safe.
