Where have the pm files gone for camera control
l8nite4me
Post by l8nite4me »
I need to write some custom camera controls and need the pm file location in 1.24.x or for the replacement script. I thought I read somewhere that ZoneMinder had gone away from the pm files in the current version and has started controlling cameras via a script. If so what is the script that controls ptz on cameras now?
Thanks in Advance
Phil, this project has grown more than I would have ever imagined
l8nite4me
l8nite4me
Post by l8nite4me »
I will try to ask this question another way.
I am reading the Control Scripts section of the documentation here http://www.zoneminder.com/wiki/index.ph ... ol_Scripts
It says there are a small number of sample scripts, where are the sample scripts?
thanks
l8nite4me
cordel
Post by cordel »
They are installed in the default location in your distro for perl modules.
If you do a search on your machine for any perl module, I'm sure the location will present itself.
Something typically like:
/usr/lib/perl5/vendor_perl/<version>/<module_name>/
