Hello all:
I'm having a heck of a time getting ZM 1.24.2 to capture on image using MJPEG from an Axis 215 PTZ. I've ZM working with plenty of Axis cams (211, 2100) using the MJPEG method but not for this one.
Using a browser I can easily grab an image via the following URL:
http://192.168.200.5:326/axis-cgi/jpg/i ... on=640x480
However, the message log on my box indicates the following:
"Captured image does not match expected size, check width, height and colour depth".
The camera is configured to use 4CIF so do I need to change the resolution properties under the Source tab in order to make this work? I've tried 704x480, 704x576 but nothing seems to work.
Any help is appreciated!!!
Axis 215 PTZ No Workey...
in the cgi path just use axis-cgi/jpg/image.cgi?resolution=640x480Using a browser I can easily grab an image via the following URL:
as high and width
and 640 x 480
704x480 is 4cif though
