TV-IP100
TomP
TV-IP100
Post by TomP »
I've got a trendnet ip-100W. The Wiki only states:
(http://www.zoneminder.com/wiki/index.php/Trendnet)
What setting do I use that for? are there other things like frame rate, port host path that I need to set?
Thanks,
Tom
l8nite4me
Post by l8nite4me »
When you setup the camera that information goes in the source tab for "Remote Host path"
As long as you have not changed any of the defaults on the camera nothing else should need to be changed.
TomP
Post by TomP »
OK - I put in the line as segusted. I was also required to put in a height, width and Remote Source Name. For Remote Source Name I tried just the ip and I tried uid:pw@IP. The good new is that I'm not getting a blank page any more. The bad news is that I'm getting a big, black, box with 0 fps. Any ideas?
Tom
