problem with ram [SOLVED]
antuz88
Post by antuz88 »
hi, i have a server with zoneminder installed. i have an amd64 wth 8gb ram.
run zoneminder 1.24-2 on debian lenny 5.0.4
the problem is that zoneminder gradually saturated the ram and can't empty if i don't reboot the system.
Any ideas?
[SOLVED] Was a problem of library
antuz88
Post by antuz88 »
can be a problem with some library or driver of zoneminder?
ideas?
help plsss
DREMA
Post by DREMA »
What else do you run on your system?
Do you have zm configured with nmap=YES ?
antuz88
Post by antuz88 »
where can i see if nmap=yes ? in my zm.conf there isn't this value
on my system i run nothing of special...when zoneminder is stopped the ram used is 600-700mb
thanks for your reply
bikeidaho
Solved
Post by bikeidaho »
How did you solve this problem? It would be helpful for an explanation.
