System Failure
tdukes
System Failure
Post by tdukes »
My system crashed a couple weeks ago. Zoneminder was working at the time.
I tried to re-install from backup but found my backup was no good so I
re-installed everything from scratch.
I tried installing zm 1.24.4 but couldn't get it to compile on my centos 5.5
system so I went back to 1.23.3 the version I was using before the crash.
I can get one camera working. When I add the second, all I get is a blue screen. When I add a third, all cameras show up red under the source column in zoneminder and the first camera stops working.
I can run xawtv and get a picture from each camera. I'm thinking it must be a ffmpeg problem as it is a different version than I originally installed.
Any ideas? What is the current ' verified working' version of ffmpeg?
Thanks,
Eddie
________
YAMAHA R15 SPECIFICATIONS
tdukes
Post by tdukes »
Don't donate to this 'cause' as I did 2 years ago. The support is crap, the software is crap, the documentation is crap!
________
MICHIGAN MEDICAL MARIJUANA DISPENSARIES
kingofkya
Post by kingofkya »
Well lets see you posted no info related to your problem you may have only posted "it doesn't work help me"
POST YOUR LOGS OR COMPILE ERRORS
and read this
http://catb.org/~esr/faqs/smart-questions.html
