Axis camera not sending trigger.
Yamanipanuchi
Post by Yamanipanuchi »
I've searched for an answer to this problem and cannot find anything.
I have several axis 209 camera's, im trying to setup the device to send a TCP trigger to Zoneminder. I've got it to work once. Havent changed any of the settings, but now it wont work.
Wondering if anyone else out there has had similare problems?
kingofkya
Post by kingofkya »
Whats int zm trigger log.
Yamanipanuchi
I cannot find a zmtrigger.log anywhere.
I cant really tell if its the camera not sending the trigger or the system not receiving it.
I suspect the camera because i've had similar problem with FTP uploading. It would work sometimes and not most of the time.
kingofkya
Post by kingofkya »
My axis 211m took me a while to get zones working correctly with zmtrigger so it may just need to be tuned.
Yamanipanuchi
I've determined this problem is related to the camera. I've setup the camera directly connected to a laptop and used wireshark to view the network traffic. The camera sends the notification for the first 5-6 second of power up and then stops.
I'm wondering if there's anyone else out there that's dealt with this same problem?
I'm seen this on 3 different models. 207 209fd and 221.
