Starting ZoneMinder: Can't locate ZoneMinder.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.10.1 /usr/local/share/perl/5.10.1 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.10 /usr/share/perl/5.10 /usr/local/lib/site_perl) at /usr/local/bin/zmpkg.pl line 46.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 46.
failure
How do I uninstall ZoneMinder if I used the SVN to install it?
Also, since the upgrade, I haven't been able to view my USB camera via mjpg_streamer. Is this something I should also uninstall and reinstall? I'd rather not have to use the mjpg_streamer program to get the video, I'd much rather have ZM see the camera (Model: Logitech QuickCam Communicate Deluxe) locally, but I haven't figured out how to get it to work properly. I'm kind of hoping reinstalling ZM will fix that problem too. Has anyone else been able to set up a USB Logitech camera directly with ZM? If so, please let me know what settings you used.
