Export failed error
Export failed error
I'm try to download a group of videos of a few events, so I checked the events and chose to export..but I always get an export failed error..that's it. Are there any common things to try to fix this?
SOLVED - Export of zip files
Ok. SOLVED at least for ZM on Ubuntu 10.04 lucid - x64 kernel. The export when checking the "zip" format was failing as there was no package to provide the zip service installed. I installed the package "zip" using aptitude and it worked after that.
I suspect if you are using a different distro, install the package that will provide use of the command "zip" and it will work for you.
Jeff
Jeff
Continuing Issues
I have the same problem, and I do have the ZIP packages installed. Ubuntu 10.04, Zoneminder 1.24.2. Anyhow, I am able to export files on the local machine that ZM is running on, but on a remote machine, I am unable to do so. I did the "export permissions fix" as told in the documentation from using a .DEB package installation. Below are my logs of a video viewing event, followed by a file export event.
Any ideas?
[Mon Jun 14 23:08:58 2010] [error] [client 192.168.0.18] SQL-ERROR(ACFA47): select E.*,M.Name as MonitorName,M.Width,M.Height,M.DefaultRate,M.DefaultScale from Events as E inner join Monitors as M on E.MonitorId = M.Id where E.Id = undefined, referer: http://192.168.0.4:7290/zm/index.php?view=event&eid=21&filter[terms][0][attr]=MonitorId&filter[terms][0][op]=%3D&filter[terms][0][val]=2&sort_field=StartTime&sort_asc=1&page=1
[Mon Jun 14 23:08:58 2010] [error] [client 192.168.0.18] SQL-ERROR(ACFA47): Unknown column 'undefined' in 'where clause', referer: http://192.168.0.4:7290/zm/index.php?view=event&eid=21&filter[terms][0][attr]=MonitorId&filter[terms][0][op]=%3D&filter[terms][0][val]=2&sort_field=StartTime&sort_asc=1&page=1
[Mon Jun 14 23:08:58 2010] [error] [client 192.168.0.18] File does not exist: /var/www/favicon.ico
[Mon Jun 14 23:22:47 2010] [error] [client 192.168.0.18] No event id(s) supplied, referer: http://192.168.0.4:7290/zm/index.php?view=export&eid=undefined
[Mon Jun 14 23:22:47 2010] [error] [client 192.168.0.18] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/event.php',\n 'line' => 5,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'No event id(s) supplied',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/event.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.0.4:7290/zm/index.php?view=export&eid=undefined
Chrome is the problem
I had the same problem, export failed... with Google Chrome. After reading the comments in this post I tried IE6, works perfect. Thanks!
TimB
