ACTi IP Camera Configuration - No display
caprio
Post by caprio »
I just installed ZM 1.24.1. I'm using ACTi IP (Model ACM-3511) camera.
I've got the camera working. By working I mean I can use the ffmpeg utility 'ffplay'
to view the video stream (ffplay rtsp://10.16.1.14:7070)
It appears that the images are being captured in ZM however I can not see the image
in my browser. I tried firefox and MSIE. All I get is a white box with a black thin border.
Inside the box I see a square with a red X and the name of my monitor zone.
If I right click on the red X and do properties I get;
nph-zms?mode=single&monitor=1&scale=100&connkey=264095&rand=1237853072&1237853271288
The display at the bottom says State: Idle - 9.19 fps. fps changes but it always says
idle.
Any ideas?
Thank you.
/var/log/messages:
Mar 23 16:52:27 emu zmc_m1[16863]: WAR [Discarding partial frame 351, 13140 bytes]
Mar 23 16:52:27 emu zmc_m1[16863]: WAR [Discarding incomplete frame 351, 0 bytes]
Mar 23 16:53:49 emu zmc_m1[16863]: INF [TestZone: 1000 - Capturing at 7.75 fps]
Mar 23 16:55:12 emu nagios: Auto-save of retention data completed successfully.
Mar 23 16:55:56 emu zmc_m1[16863]: INF [TestZone: 2000 - Capturing at 7.87 fps]
Mar 23 16:58:01 emu zmc_m1[16863]: INF [TestZone: 3000 - Capturing at 8.00 fps]
Mar 23 17:00:09 emu zmc_m1[16863]: INF [TestZone: 4000 - Capturing at 7.81 fps]
Mar 23 17:01:42 emu zmc_m1[16863]: WAR [Packet in sequence, gap 5]
Mar 23 17:01:42 emu zmc_m1[16863]: WAR [Discarding partial frame 4745, 13140 bytes]
Mar 23 17:01:42 emu zmc_m1[16863]: WAR [Discarding incomplete frame 4745, 0 bytes]
Mar 23 17:02:15 emu zmc_m1[16863]: INF [TestZone: 5000 - Capturing at 7.94 fps]
Mar 23 17:04:22 emu zmc_m1[16863]: INF [TestZone: 6000 - Capturing at 7.87 fps]
Mar 23 17:06:29 emu zmc_m1[16863]: INF [TestZone: 7000 - Capturing at 7.87 fps]
newvisionantenna
Post by newvisionantenna »
Send me a PM and I'll try and add it to my online demo and let you know if it works or not.
cordel
Post by cordel »
If it's shows capturing, and you get a red [x] then something is off in your Apache config. Check the Apache error log.
dim3000
Post by dim3000 »
bump.
exactly the same problem, any suggestions?
ingrjhernandez
Post by ingrjhernandez »
I had a similar problem in VGA resolution (not in 320x240) in ACTi 4001 cam. I could get rid of it simply checking "RTP B2 Frame Enable" option in "video configuration" (I assume you are using MPEG4 encoding and RTSP). Also, to get a good response, set the same FPS in cam and zoneminder.
Either check if you have the last firmware version, I updated recently and the image quality has improved considerably.
I hope this can help you.
Regards,
Rodrigo.
ddalton
Re: ACTi IP Camera Configuration - No display
Post by ddalton »
Can you post your Acti-4001 web configuration and zoneminder configuration that works, currently I just get a grey bar with 1.24.2 rtsp udp no authenication at 640x480
