Here i post all my configuration and error messages
My Server is
OSVER: Ubuntu Server 9.04
Kernel : 2.6.28-18-server
ZMVER: ZoneMinder 1.24.2
RAM: 1GB DDR2
I use a Card ETHER9808
And i put this in modprobe
more /etc/modprobe.d/options.conf
options saa7134 card=70,70,70,70,70,70,70,70
Linux video capture interface: v2.00
saa7134[0]: Huh, no eeprom present (err=-5)?
[ 8.053992] saa7134[0]: registered device video1 [v4l2]
[ 8.054022] saa7134[0]: registered device vbi1
[ 8.054071] saa7134 0000:03:09.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 8.054080] saa7134[1]: found at 0000:03:09.0, rev: 1, irq: 17, latency: 15, mmio: 0xfdcfe000
[ 8.054088] saa7134 0000:03:09.0: setting latency timer to 64
[ 8.054095] saa7134[1]: subsystem: 1131:0000, board: Compro Videomate DVB-T300 [card=70,insmod option]
[ 8.054145] saa7134[1]: board init: gpio is 10000
[ 8.054228] input: saa7134 IR (Compro Videomate DV as /devices/pci0000:00/0000:00:1e.0/0000:02:04.0/0000:03:09.0/input/input6
[ 8.196301] saa7134[1]: Huh, no eeprom present (err=-5)?
[ 8.197844] saa7134[1]: registered device video2 [v4l2]
[ 8.197877] saa7134[1]: registered device vbi2
[ 8.197920] saa7134 0000:03:0a.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 8.197930] saa7134[2]: found at 0000:03:0a.0, rev: 1, irq: 18, latency: 15, mmio: 0xfdcfd000
[ 8.197939] saa7134 0000:03:0a.0: setting latency timer to 64
[ 8.197946] saa7134[2]: subsystem: 1131:0000, board: Compro Videomate DVB-T300 [card=70,insmod option]
[ 8.197993] saa7134[2]: board init: gpio is 10000
[ 8.198075] input: saa7134 IR (Compro Videomate DV as /devices/pci0000:00/0000:00:1e.0/0000:02:04.0/0000:03:0a.0/input/input7
[ 8.326282] saa7134[2]: Huh, no eeprom present (err=-5)?
[ 8.327668] saa7134[2]: registered device video3 [v4l2]
[ 8.327696] saa7134[2]: registered device vbi3
[ 8.327731] saa7134 0000:03:0b.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 8.327740] saa7134[3]: found at 0000:03:0b.0, rev: 1, irq: 19, latency: 15, mmio: 0xfdcfc000
[ 8.327749] saa7134 0000:03:0b.0: setting latency timer to 64
[ 8.327755] saa7134[3]: subsystem: 1131:0000, board: Compro Videomate DVB-T300 [card=70,insmod option]
[ 8.327779] saa7134[3]: board init: gpio is 10000
[ 8.327857] input: saa7134 IR (Compro Videomate DV as /devices/pci0000:00/0000:00:1e.0/0000:02:04.0/0000:03:0b.0/input/input8
[ 8.456280] saa7134[3]: Huh, no eeprom present (err=-5)?
[ 8.457667] saa7134[3]: registered device video4 [v4l2]
[ 8.457701] saa7134[3]: registered device vbi4
[ 8.457735] saa7134 0000:03:0c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 8.457744] saa7134[4]: found at 0000:03:0c.0, rev: 1, irq: 16, latency: 15, mmio: 0xfdcfb000
[ 8.457752] saa7134 0000:03:0c.0: setting latency timer to 64
[ 8.457758] saa7134[4]: subsystem: 1131:0000, board: Compro Videomate DVB-T300 [card=70,insmod option]
[ 8.457783] saa7134[4]: board init: gpio is 10000
[ 8.457860] input: saa7134 IR (Compro Videomate DV as /devices/pci0000:00/0000:00:1e.0/0000:02:04.0/0000:03:0c.0/input/input9
[ 8.596280] saa7134[4]: Huh, no eeprom present (err=-5)?
[ 8.597619] saa7134[4]: registered device video5 [v4l2]
[ 8.597648] saa7134[4]: registered device vbi5
[ 8.597680] saa7134 0000:03:0d.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 8.597689] saa7134[5]: found at 0000:03:0d.0, rev: 1, irq: 17, latency: 15, mmio: 0xfdcfa000
[ 8.597697] saa7134 0000:03:0d.0: setting latency timer to 64
[ 8.597703] saa7134[5]: subsystem: 1131:0000, board: Compro Videomate DVB-T300 [card=70,insmod option]
[ 8.597729] saa7134[5]: board init: gpio is 10000
[ 8.597803] input: saa7134 IR (Compro Videomate DV as /devices/pci0000:00/0000:00:1e.0/0000:02:04.0/0000:03:0d.0/input/input10
[ 8.726280] saa7134[5]: Huh, no eeprom present (err=-5)?
[ 8.727650] saa7134[5]: registered device video6 [v4l2]
[ 8.727679] saa7134[5]: registered device vbi6
[ 8.727713] saa7134 0000:03:0e.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 8.727722] saa7134[6]: found at 0000:03:0e.0, rev: 1, irq: 18, latency: 15, mmio: 0xfdcf9000
[ 8.727730] saa7134 0000:03:0e.0: setting latency timer to 64
[ 8.727736] saa7134[6]: subsystem: 1131:0000, board: Compro Videomate DVB-T300 [card=70,insmod option]
[ 8.727761] saa7134[6]: board init: gpio is 10000
[ 8.727837] input: saa7134 IR (Compro Videomate DV as /devices/pci0000:00/0000:00:1e.0/0000:02:04.0/0000:03:0e.0/input/input11
[ 8.866296] saa7134[6]: Huh, no eeprom present (err=-5)?
[ 8.867643] saa7134[6]: registered device video7 [v4l2]
[ 8.867673] saa7134[6]: registered device vbi7
[ 8.867711] saa7134 0000:03:0f.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 8.867720] saa7134[7]: found at 0000:03:0f.0, rev: 1, irq: 19, latency: 15, mmio: 0xfdcf8000
[ 8.867729] saa7134 0000:03:0f.0: setting latency timer to 64
[ 8.867736] saa7134[7]: subsystem: 1131:0000, board: Compro Videomate DVB-T300 [card=70,insmod option]
[ 8.867768] saa7134[7]: board init: gpio is 10000
[ 8.867848] input: saa7134 IR (Compro Videomate DV as /devices/pci0000:00/0000:00:1e.0/0000:02:04.0/0000:03:0f.0/input/input12
[ 8.996282] saa7134[7]: Huh, no eeprom present (err=-5)?
[ 8.997622] saa7134[7]: registered device video8 [v4l2]
[ 8.997657] saa7134[7]: registered device vbi8
[ 9.060113] dvb_init() allocating 1 frontend
[ 9.104158] tda10046: chip is not answering. Giving up.
[ 9.104317] saa7134[0]/dvb: frontend initialization failed
[ 9.104362] dvb_init() allocating 1 frontend
[ 9.105025] tda10046: chip is not answering. Giving up.
[ 9.105175] saa7134[1]/dvb: frontend initialization failed
[ 9.105222] dvb_init() allocating 1 frontend
[ 9.105884] tda10046: chip is not answering. Giving up.
[ 9.106032] saa7134[2]/dvb: frontend initialization failed
[ 9.106077] dvb_init() allocating 1 frontend
[ 9.106737] tda10046: chip is not answering. Giving up.
[ 9.106886] saa7134[3]/dvb: frontend initialization failed
[ 9.106930] dvb_init() allocating 1 frontend
[ 9.107591] tda10046: chip is not answering. Giving up.
[ 9.107738] saa7134[4]/dvb: frontend initialization failed
[ 9.107783] dvb_init() allocating 1 frontend
[ 9.108446] tda10046: chip is not answering. Giving up.
[ 9.108614] saa7134[5]/dvb: frontend initialization failed
[ 9.108676] dvb_init() allocating 1 frontend
[ 9.109338] tda10046: chip is not answering. Giving up.
[ 9.109506] saa7134[6]/dvb: frontend initialization failed
[ 9.109569] dvb_init() allocating 1 frontend
[ 9.110256] tda10046: chip is not answering. Giving up.
[ 9.110427] saa7134[7]/dvb: frontend initialization failed
[ 9.288939] lp: driver loaded but no devices found
03:08.0 Multimedia controller: Philips Semiconductors SAA7134/SAA7135HL Video Broadcast Decoder (rev 01)
Subsystem: Philips Semiconductors Device 0000
Flags: bus master, medium devsel, latency 64, IRQ 16
Memory at fdcff000 (32-bit, non-prefetchable) [size=1K]
Capabilities: <access>
Kernel driver in use: saa7134
Kernel modules: saa7134
X 8 times, because i have 8 SAA7134 in this card
My memory info
> free
total used free shared buffers cached
Mem: 2052252 937168 1115084 0 339692 409732
-/+ buffers/cache: 187744 1864508
Swap: 6008268 0 6008268
>cat /proc/interrupts
CPU0 CPU1
0: 122 0 IO-APIC-edge timer
1: 2 0 IO-APIC-edge i8042
8: 1 0 IO-APIC-edge rtc0
9: 0 0 IO-APIC-fasteoi acpi
14: 0 0 IO-APIC-edge ata_piix
15: 0 0 IO-APIC-edge ata_piix
16: 128 0 IO-APIC-fasteoi uhci_hcd:usb5, saa7134[0], bttv0, HDA Intel, saa7134[4]
17: 2 0 IO-APIC-fasteoi saa7134[1], saa7134[5]
18: 6 0 IO-APIC-fasteoi uhci_hcd:usb4, saa7134[2], saa7134[6]
19: 162655 0 IO-APIC-fasteoi ata_piix, uhci_hcd:usb3, saa7134[3], saa7134[7]
23: 0 0 IO-APIC-fasteoi ehci_hcd:usb1, uhci_hcd:usb2
2302: 7582 0 PCI-MSI-edge eth0
NMI: 0 0 Non-maskable interrupts
LOC: 263263 317098 Local timer interrupts
RES: 1109 1071 Rescheduling interrupts
CAL: 31 91 Function call interrupts
TLB: 3993 5210 TLB shootdowns
SPU: 0 0 Spurious interrupts
ERR: 0
MIS: 0
---- LÃmites memoria compartida ----
número máx. segmentos = 4096
tamaño máx. segmento (kbytes) = 316800
máximo total de memoria compartida (kbytes) = 1297612800
tamaño mÃn. segmento (bytes) = 1
------ LÃmites semáforo --------
número máximo de matrices = 128
máx. semáforos por matriz = 250
máx. semáforos sistema = 32000
máx. oper. por llamada semop = 32
valor máx. semáforo = 32767
------ Mensajes: lÃmites -------
máx. colas sistema = 1706
tamaño máx. mensaje (bytes) = 8192
tamaño máx. predeterminado cola (bytes) = 16384
more /etc/sysctl.conf
kernel.shmall = 324403200
kernel.shmmax = 324403200
Video Device: /dev/video1
General Capabilities
Driver: saa7134
Card: Compro Videomate DVB-T300
Bus: PCI:0000:03:08.0
Version: 0.2.14
Type: 0x5010015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Has tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp gray (GREY)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
24 bpp RGB, be (RGB3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2 packed, YUYV (YUYV)
4:2:2 packed, UYVY (UYVY)
4:2:2 planar, Y-Cb-Cr (422P)
4:2:0 planar, Y-Cb-Cr (YU12)
4:2:0 planar, Y-Cb-Cr (YV12)
Crop Capabilities
Bounds: 720 x 578
Default: 720 x 576
Current: 720 x 576
Inputs: 3
Input 0
Type: Tuner
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Jun 19 16:59:32 NxtZoneMinder kernel: [ 968.983715] saa7134[7]/irq: looping -- clearing PE (parity error!) enable bit
Jun 19 16:59:32 NxtZoneMinder kernel: [ 968.991272] saa7134[3]/irq: looping -- clearing PE (parity error!) enable bit
Jun 19 16:59:32 NxtZoneMinder kernel: [ 968.991438] saa7134[7]/irq: looping -- clearing PE (parity error!) enable bit
Jun 19 16:59:32 NxtZoneMinder kernel: [ 969.007456] saa7134[3]/irq: looping -- clearing PE (parity error!) enable bit
n 21 10:27:36 NxtZoneMinder zmdc[2693]: INF [Starting pending process, zmc -d /dev/video2]
Jun 21 10:27:36 NxtZoneMinder zmdc[2693]: INF ['zmc -d /dev/video2' starting at 10/06/21 10:27:36, pid = 3246]
Jun 21 10:27:36 NxtZoneMinder zmdc[2693]: INF [Starting pending process, zmc -d /dev/video5]
Jun 21 10:27:36 NxtZoneMinder zmdc[2693]: INF ['zmc -d /dev/video5' starting at 10/06/21 10:27:36, pid = 3247]
Jun 21 10:27:36 NxtZoneMinder zmdc[3246]: INF ['zmc -d /dev/video2' started at 10/06/21 10:27:36]
Jun 21 10:27:36 NxtZoneMinder zma_m25[2734]: WAR [Waiting for capture daemon]
Jun 21 10:27:36 NxtZoneMinder zmdc[3247]: INF ['zmc -d /dev/video5' started at 10/06/21 10:27:36]
Jun 21 10:27:36 NxtZoneMinder zmc_dvideo2[3246]: INF [Debug Level = 0, Debug Log = <none>]
Jun 21 10:27:36 NxtZoneMinder zmc_dvideo5[3247]: INF [Debug Level = 0, Debug Log = <none>]
Jun 21 10:27:36 NxtZoneMinder zmc_dvideo2[3246]: INF [New Debug Level = 4, New Debug Log = /tmp/zm_debug.log.03246]
Jun 21 10:27:36 NxtZoneMinder zmc_dvideo5[3247]: INF [New Debug Level = 4, New Debug Log = /tmp/zm_debug.log.03247]
Jun 21 10:27:36 NxtZoneMinder zmc_dvideo2[3246]: INF [Starting Capture]
Jun 21 10:27:36 NxtZoneMinder zmc_dvideo5[3247]: INF [Starting Capture]
Jun 21 10:27:36 NxtZoneMinder zma_m24[2725]: WAR [Waiting for capture daemon]
Jun 21 10:27:37 NxtZoneMinder zmdc[2693]: INF [Starting pending process, zmc -d /dev/video8]
Jun 21 10:27:37 NxtZoneMinder zmdc[3248]: INF ['zmc -d /dev/video8' started at 10/06/21 10:27:37]
Jun 21 10:27:37 NxtZoneMinder zmdc[2693]: INF ['zmc -d /dev/video8' starting at 10/06/21 10:27:37, pid = 3248]
Jun 21 10:27:37 NxtZoneMinder zma_m25[2734]: WAR [Waiting for capture daemon]
Jun 21 10:27:37 NxtZoneMinder zmc_dvideo8[3248]: INF [Debug Level = 0, Debug Log = <none>]
Jun 21 10:27:37 NxtZoneMinder zmc_dvideo8[3248]: INF [New Debug Level = 4, New Debug Log = /tmp/zm_debug.log.03248]
Jun 21 10:27:37 NxtZoneMinder zmc_dvideo8[3248]: INF [Starting Capture]
Jun 21 10:27:37 NxtZoneMinder zma_m24[2725]: WAR [Waiting for capture daemon]
Jun 21 10:27:38 NxtZoneMinder zma_m25[2734]: WAR [Waiting for capture daemon]
Jun 21 10:27:38 NxtZoneMinder zma_m24[2725]: WAR [Waiting for capture daemon]
Jun 21 10:27:39 NxtZoneMinder zma_m25[2734]: WAR [Waiting for capture daemon]
Jun 21 10:27:39 NxtZoneMinder zma_m24[2725]: WAR [Waiting for capture daemon]
Thanks you very much for your help.
Regards
