I'll be putting a 1.20.1 out in the next day or two, once I'm confident most of the authenticate issues are resolved. I'd be interested to hear whether that's the case or not.
Phil
zm-1.19.5-1.FC3.i386.rpm
- zoneminder
- Site Admin
- Contact:
oskin,
What version of mysql Client are you using that has a shared Libs of so.14?
The client that is packaged with Fedora is so.10.
Anyone installing the package must update mysql to the same version your using.
I'll repackage on my build machine so that zm is configured for the standard client packaged with Fedora and post it on ftp://cordel.no-ip.info/pub/Fedora/3/RPMS/
File is zm-1.20.0-3.FC3.i386.rpm
This will work with the packages that are on the Fedora Core 3 CD's
Cheers,
Cordel
_______________________________________
Update 2005-3-15
Files on the FTP server have moved but are still available.
ftp://cordel.no-ip.info/pub/linux/zonem ... Extra-RPMS
There also is a repository here for YUM both are the same server but if I find a location with more bandwidth the ftp server and repo will follow only the following urls
ftp://download.computerntelecom.com/pub ... re/3/i386/
http://download.computerntelecom.com/pu ... re/3/i386/
Cheers,
Cordel
Update 2005-3-15
Ross,
Sorry, I have not so understood a reason. Probably because of my not so good knowledge of English language...
If functionality of "zmconfig.pl -noi -nor" command is necessary is does zmoptions.
Cordel,
I already so a long time use mysql 4.1.x, that have forgotten, what version is included into FC3...
The choice of the version 4.1.x was affected with such reasons, as: absence of support of versions 3.x; necessity of support of encodings UCS2 and UTF8. Everything, that is necessary for upgrade FC3 up to mysql-4.1.9 is here: ftp://oskin.ru/pub/linux/RedHat/MyRPMS/ ... ore/3/RPMS
Serg.
Cordel,
Serg.
hello everybody!
I'm sorry oskin, but i can't download on Your http and ftp site.
I download only the first 29ko on each package and it's corrupt (normal....).
i'm only interresting by the 1.19.5.src and 1.20.scr for adapt to SME(based on RH7.3).
please, can you send me by mail the .src or resolve the problem on your side.
Great JOB!!
Great JOB!!
