I just installed Ubuntu 10.04 and ZM 1.24.2 in a new laptop. I wanted to compare cpu loads and capture speeds with my actual setup (a desktop computer).
After opening the montage view in both computers, I notice that in one of them, the FPS rate is shown under the image, but not in the other...
I checked the configuration and seems the same, is it a bug?. What do I have to check to make it work???
Regards,
PacoLM
FPS rate not shown in 1.24.2
I tried this because I have the same exact problem. No FPS showing in any window anywhere. It did not solve the problem for me. I have many other issues with this software and have tried multiple suggestion from multiple people on here and basically I am getting nowhere. This thing has got more bugs than a Louisiana swamp.
I don't know wether to wind my butt or scratch my watch.
I accidently fixed my FPS not showing up. Now the FPS shows up on everything and shows up correctly every time. Please go to this post to see what I did.
http://www.zoneminder.com/forums/viewtopic.php?t=16191
I hope that helps
I hope that helps
