Hi...help!!!!
I've ubunto + zoneminder 1.24.2
Now im going to http:\\ip ubuntu machine
now i going new monitor for my cam Ip
but i see a black monitor and state IDLE - 0.00 fbs
Why???? help ne please !!!!
You must supply the "remote host path". Also check your resolution, I believe height might need to be 640. Try probing the camera or check the pre sets (both on the source pop up) to see if the correct settings are available there. Maybe search the forums for your camera type to see if they are listed. Or bring up your browser and point it at the camera, when you get a picture try right click and check the properties, a path will be listed there and can be an easy way to start the fine tuning process. If this fails post your camera type and someone with experience will chime in with the correct source settings.
