Unifly 101 IP Cam not working in Zoneminder (环宇飞扬)
n00bita
Post by n00bita »
Dears,
I couldn't get an IP Camera work in monitor mode. Could anyone help me? This camera compression type seems OK, which is M-JPEG, and you don't need an ActiveX to open its HTTP live streams, I can open the IP camera in firefox browser.
I bought the IP Camera from China. In English it's called Unifly 101. You won't find the camera if you are using the word "Unifly 101". You have to type in Chinese name "环宇飞扬 101" either in www.google.com or www.baidu.com
Version
Zoneminder version 1.24.1
Here is the link of the product
http://item.taobao.com/item.htm?id=5420172336
Here is the specification (Google Translate):
Sensor: High Resolution 1 / 4 "CMOS image sensor
Lens: 5 high-resolution infrared lens glass
Infrared light up: Support 6 infrared LED, illumination automatically open
Image Resolution: (640x480) / (320x240) / (160x120) Optional
Image Compression: M-JPEG
Image frame rate: the case of bandwidth to allow video image transmission can achieve 30 frames / sec
Sensing and control: support for an external volume sensor switch 2, a relay switch output
Alarm Detection: support alarm can be triggered
Video transmission: network camera supports up to 12 simultaneous users to access
User access: Built-in Web Server, allow remote users to directly access the Web browser, network camera
Certification / Encryption: Users with password access to the network camera, 3-level access permissions to ensure users safety
Network Protocols: TCP / IP, UDP, IMCP, SMTP, HTTP, FTP, DNS, DDNS DHCP, PPPoE
Network connection :10-100Base-T Ethernet interface, RJ45 connector
Supporting software: distribution <IPCam> and <16> Software
Software upgrade: Support FTP software upgrade
Power supply: DC 5V/1A external power supply
My latest /var/log/messages when I tried to view the camera:
Jul 25 22:31:00 n00bita-desktop zmdc[6525]: INF [Starting pending process, zmc -m 1]
Jul 25 22:31:00 n00bita-desktop zmdc[6525]: INF ['zmc -m 1' starting at 10/07/25 22:31:00, pid = 9440]
Jul 25 22:31:00 n00bita-desktop zmdc[9440]: INF ['zmc -m 1' started at 10/07/25 22:31:00]
Jul 25 22:31:00 n00bita-desktop zmc_m1[9440]: INF [Debug Level = 0, Debug Log = <none>]
Jul 25 22:31:00 n00bita-desktop zmc_m1[9440]: INF [Starting Capture]
Jul 25 22:31:06 n00bita-desktop zms[9460]: INF [Debug Level = 0, Debug Log = <none>]
Jul 25 22:31:06 n00bita-desktop zms[9460]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Jul 25 22:31:20 n00bita-desktop zmdc[6525]: INF [Starting pending process, zmc -m 1]
Jul 25 22:31:20 n00bita-desktop zmdc[6525]: INF ['zmc -m 1' starting at 10/07/25 22:31:20, pid = 9470]
Jul 25 22:31:20 n00bita-desktop zmdc[9470]: INF ['zmc -m 1' started at 10/07/25 22:31:20]
Jul 25 22:31:20 n00bita-desktop zmc_m1[9470]: INF [Debug Level = 0, Debug Log = <none>]
Jul 25 22:31:20 n00bita-desktop zmc_m1[9470]: INF [Starting Capture]
Jul 25 22:31:21 n00bita-desktop pulseaudio[3979]: ratelimit.c: 1 events suppressed
Jul 25 22:31:44 n00bita-desktop zmu[9472]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Jul 25 22:31:45 n00bita-desktop zmu[9474]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
tail -f /tmp/zmdc.log
07/26/10 21:04:40.113312 zmdc[1962].ERR ['zmc -m 3' exited abnormally, exit status 255]
07/26/10 21:05:00.083859 zmdc[1962].INF [Starting pending process, zmc -m 3]
07/26/10 21:05:00.085681 zmdc[1962].INF ['zmc -m 3' starting at 10/07/26 21:05:00, pid = 5065]
07/26/10 21:05:00.162534 zmdc[1962].ERR ['zmc -m 3' exited abnormally, exit status 255]
07/26/10 21:05:40.050229 zmdc[1962].INF [Starting pending process, zmc -m 3]
07/26/10 21:05:40.052035 zmdc[1962].INF ['zmc -m 3' starting at 10/07/26 21:05:40, pid = 5068]
07/26/10 21:05:40.144585 zmdc[1962].ERR ['zmc -m 3' exited abnormally, exit status 255]
07/26/10 21:07:00.084552 zmdc[1962].INF [Starting pending process, zmc -m 3]
07/26/10 21:07:00.086395 zmdc[1962].INF ['zmc -m 3' starting at 10/07/26 21:07:00, pid = 5125]
07/26/10 21:07:00.169794 zmdc[1962].ERR ['zmc -m 3' exited abnormally, exit status 255]
/tmp/zmwatch.log
07/26/10 20:39:07.416363 zmwatch[2069].INF [Watchdog starting]
07/26/10 20:39:07.416523 zmwatch[2069].INF [Watchdog pausing for 30 seconds]
07/26/10 21:00:07.592846 zmwatch[2069].ERR [Can't get shared memory id '7a6d0003', 3: No such file or directory]
Very appreciate if someone can help me
kingofkya
Post by kingofkya »
You need to set your systems shared memory. Or you cam is sending corrupted jpegs.
Flash_
Post by Flash_ »
Have you actually found the proper path for the jpg or mjpeg stream?
This usually is not just the ip. Look at the source of the user webpage if available, see if you can find a .jpg link in there which when you type that into your browser's location bar should give you a picture (not mjpeg in Iexplore)
Once you have that, right click and check properties to get the accurate height and width, and put all that info into zm.
