Copying Recordings to DVD-RW for Security
metallica1973
Post by metallica1973 »
I am using Zoneminer 1.24X and have it configured to recording via frames(jpg) at 30fps. I have been asked to copy a certain recording at a certain date and time to a DVD-RW for the owner. How can I accomplish this task?
bb99
Post by bb99 »
Single click on the event you want to record, at the top click export. The rest depends on your set up but that should get you headed in the right direction.
metallica1973
Many many thanks you's but after an export I can see that everything is in a folder with just the jpeg frames. How would one play them back to show the recordings? What I mean is how can I play them back to show the recording outside of Zoneminder to lets say show my boss the video? I hope that came out right?
bb99
Post by bb99 »
My mistake, click on generate video then export video to anywhere you want using export video tick or burn the video to DVD from current location. Just discovered my generate video has issues I need to fix....
