Hallo Zusammen,
versuche eine Mobotix M12 einzubinden:
der Post http://www.zoneminder.com/forums/viewtopic.php?t=13726 beschreibt:
http://ip/control/faststream.jpg?stream ... re&e=.mjpg
Ich kann jedoch die Quelle nur angeben bis zu folgender Zeichenkette:
http://ip/control/faststream.jpg?stream=full&fps=0&err
irgendeine Idee?
Ubuntu Linux 10.04, ZM v1.24.2
source path to long - mobotix M12
shorten the path
usually you don't need the http:// part of it anyways - IF you've checked HTTP as the protocol, and for the IP you could create an entry in your hosts file and call your cam e.g. 'C1'
unfortunately the problem is mysql - there's some variable that handles the path and was set up too short, so unless you change/recompile some parts you're limited to the short paths
pls send emails to 'myusername at google dot com'
