Gentoo, 'forbidden' web page
twomonkeysayoyo
Post by twomonkeysayoyo »
Hi, trying to install zoneminder on a fresh gentoo box. Follwed http://www.zoneminder.com/wiki/index.ph ... o_ZioPRoTo (as best possible, had to extrapolate a few steps).
Anyway, ran into some permission issues when trying to start up Zoneminder, and have an inability to get to the Zoneminder site on my box.
When starting with the regular startup script I get:
Can't connect: Permission denied at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder/Debug.pm line 349
        ZoneMinder::Debug::Fatal('Can\'t connect: Permission denied') called at /usr/bin/zmdc.pl line 168
When starting up with the startup script from wiki page above I get the same thing.
/var/log/messages gives me
May 27 19:36:39 camerahost zmpkg[7305]: INF [Command: start]
May 27 19:36:39 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/bin/true
May 27 19:36:39 camerahost sudo: pam_unix(sudo:session): session opened for user apache by root(uid=0)
May 27 19:36:39 camerahost sudo: pam_unix(sudo:session): session closed for user apache
May 27 19:36:39 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/usr/bin/zmdc.pl check
May 27 19:36:39 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/usr/bin/zmfix
May 27 19:36:39 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/usr/bin/zmdc.pl startup
May 27 19:36:40 camerahost zmdc[7319]: INF [Server starting at 10/05/27 19:36:40]
May 27 19:36:42 camerahost zmdc[7319]: FAT [Can't bind: Address already in use]
May 27 19:36:50 camerahost zmdc[7317]: FAT [Can't connect: Permission denied]
May 27 19:36:50 camerahost zmpkg[7305]: ERR [Unable to run "sudo -u apache /usr/bin/zmdc.pl startup", output is "Starting server"]
May 27 19:36:50 camerahost rc-scripts: Failed to start ZoneMinder
Help?
twomonkeysayoyo
ok, actually I fixed the error message, but still get
Forbidden
You don't have permission to access /zoneminder/ on this server.
when I go to http://MYIP/zoneminder
http://MYIP/ gives me the page that it is supposed to.
I had to change /var/run/zm permissions to apache.apache now zoneminder starts, but I still don't get the webpage.
May 27 19:52:14 camerahost zmpkg[773]: INF [Command: start]
May 27 19:52:14 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/bin/true
May 27 19:52:14 camerahost sudo: pam_unix(sudo:session): session opened for user apache by root(uid=0)
May 27 19:52:14 camerahost sudo: pam_unix(sudo:session): session closed for user apache
May 27 19:52:14 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/usr/bin/zmdc.pl check
May 27 19:52:14 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/usr/bin/zmfix
May 27 19:52:14 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/usr/bin/zmdc.pl startup
May 27 19:52:14 camerahost zmdc[788]: INF [Server starting at 10/05/27 19:52:14]
May 27 19:52:17 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/usr/bin/zmdc.pl start zmfilter.pl
May 27 19:52:17 camerahost sudo: pam_unix(sudo:session): session opened for user apache by root(uid=0)
May 27 19:52:17 camerahost sudo: pam_unix(sudo:session): session closed for user apache
May 27 19:52:17 camerahost zmdc[788]: INF ['zmfilter.pl' starting at 10/05/27 19:52:17, pid = 813]
May 27 19:52:17 camerahost zmdc[813]: INF ['zmfilter.pl' started at 10/05/27 19:52:17]
May 27 19:52:17 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/usr/bin/zmdc.pl start zmaudit.pl -c
May 27 19:52:17 camerahost zmdc[788]: INF ['zmaudit.pl -c' starting at 10/05/27 19:52:17, pid = 817]
May 27 19:52:17 camerahost zmdc[817]: INF ['zmaudit.pl -c' started at 10/05/27 19:52:17]
May 27 19:52:17 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/usr/bin/zmdc.pl start zmwatch.pl
May 27 19:52:17 camerahost zmdc[788]: INF ['zmwatch.pl' starting at 10/05/27 19:52:17, pid = 821]
May 27 19:52:17 camerahost zmdc[821]: INF ['zmwatch.pl' started at 10/05/27 19:52:17]
May 27 19:52:17 camerahost sudo:     root : TTY=pts/0 ; PWD=/var/www/zoneminder/htdocs ; USER=apache ; COMMAND=/usr/bin/zmdc.pl start zmupdate.pl -c
May 27 19:52:17 camerahost zmfilter[813]: INF [Scanning for events]
May 27 19:52:17 camerahost zmwatch[821]: INF [Watchdog starting]
May 27 19:52:17 camerahost zmwatch[821]: INF [Watchdog pausing for 30 seconds]
May 27 19:52:17 camerahost zmdc[788]: INF ['zmupdate.pl -c' starting at 10/05/27 19:52:17, pid = 827]
May 27 19:52:17 camerahost zmdc[827]: INF ['zmupdate.pl -c' started at 10/05/27 19:52:17]
twomonkeysayoyo
looks like I might not be running php on the server. Does apache2 require mod_php or anything?
twomonkeysayoyo
ok, so, yes, I was running PHP on the server. however the installed vhost for Gentoo was crap. I don't know if anything else is wrong with it yet, but I had to add
 <FilesMatch ".(cgi|shtml|phtml|php)$"<></FilesMatch>  (subtract the odd '<' in the first part... don't know why this thing isn't formatting it correctly)
above the <Directory> in the
/etc/apache2/vhosts.d/10_zoneminder.conf
and now I have what appears to be a console.
Oo.et.oO
Post by Oo.et.oO »
the code above just plain would not work for me trying to restart apache.
i had to separate the FilesMatch tag onto two lines:
<FilesMatch>
</FilesMatch>
i can't get the above to format and include the file extension regex either...
anyway, i still get the permissions issue.
i also have two "Directory" tags in zoneminder vhosts
ideas?
zm 1.24.2 on gentoo amd64
