zms[5287]: ERR [Unable to authenticate user]
FYI-
FedoraCore3 (all standard packages from the cd with updates)
ZM 1.20.0-2 rpm
PHP Version 4.3.10
_REQUEST["ZMSESSID"] c2584bdb5a4415eba109a49aaf39c791
_REQUEST["testing"] 1
_REQUEST["sid"] 47cb8a039ffca1b03d99f00248d2a5ad
_COOKIE["ZMSESSID"] c2584bdb5a4415eba109a49aaf39c791
_COOKIE["testing"] 1
_COOKIE["sid"] 47cb8a039ffca1b03d99f00248d2a5ad
_SERVER["HTTP_HOST"] localhost
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.7.5) Gecko/20041111 Firefox/1.0
_SERVER["HTTP_ACCEPT"] text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
_SERVER["HTTP_ACCEPT_LANGUAGE"] en-us,en;q=0.5
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate
_SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,*;q=0.7
_SERVER["HTTP_KEEP_ALIVE"] 300
_SERVER["HTTP_CONNECTION"] keep-alive
_SERVER["HTTP_COOKIE"] ZMSESSID=c2584bdb5a4415eba109a49aaf39c791; testing=1; sid=47cb8a039ffca1b03d99f00248d2a5ad
_SERVER["PATH"] /sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin
_SERVER["SERVER_SIGNATURE"] <address>Apache/2.0.52 (Fedora) Server at localhost Port 80</address>
_SERVER["SERVER_SOFTWARE"] Apache/2.0.52 (Fedora)
With Oskins patch...
If I select to use passwords (authenticate) and hashed ( weither the hashed secret has a value or not) every thing works.
But If I don't chose hashed for method no video.
If I chose not to authenticate I get no video.
ZM 1.20.0-2 rpm
PHP Version 4.3.10
10.0 uses php 4.3.4, 10.1 uses 4.3.8. I checked /etc/php.ini and made sure that all settings are the same on both systems.Is there a different version of php between 10.0 and 10.1?
How would I go about checking this?Do you know if the userLogin function gets caled at all, and what it is passed if it is?
Final solution?
So if i am reading everything right, patching the source with oskins patches fixes things as long as your doing hashed authentication. correct?
Anything else does not work in some fashion?
Acceptable for how i need to deploy it, just have to start all over again and save only my config with the few changes i have already done i guess.
Help Applying Patch
For us newbies out here:
Could you step through all the steps neccessary to apply the patch without having to drop the database and do a complete new install?
If not possible or if it is preferable, for clean install what would I need to remove to have a clean system for a new re-installation?
Through out the thread, I saw several code snippets, could you repost the final, official patch again, I am confused as to what needed to be patched and which was the final patch.
Thanks,
Skydiver
Thanks,
Skydiver
I always check operation zm " as new install " and " as upgrade from previous version ". If all works correctly I do rpm package and with his help I update zm on production computer. In all cases the patch eliminated a problem. I.e. anything to clean or delete it is not necessary, enough to apply a patch and to execute "make install".Could you step through all the steps neccessary to apply the patch without having to drop the database and do a complete new install?
If you need to get "clean system" IMHO it is necessary to delete all installed files (make uninstall?) and database zm (mysqladmin drop zm).If not possible or if it is preferable, for clean install what would I need to remove to have a clean system for a new re-installation?
http://www.zoneminder.com/forums/viewto ... =6284#6284 "Posted: Sun Jan 23, 2005 7:12 pm"Through out the thread, I saw several code snippets, could you repost the final, official patch again, I am confused as to what needed to be patched and which was the final patch.
RE: Help Applying patch
OK, so a clean re-install.
I saved this to ~/downloads/zm-1.20.0/zm_user_patch and applied the patch:
Contents of src/zm_user.cpp.rej:
What next please?
Skydiver
- [morgans@video ~/downloads> rm -Rf zm-1.20.0
[morgans@video ~/downloads> tar zxvf zm-1.20.0.tar.gz
--- zm-1.20.0/src/zm_user.cpp.orig 2005-01-23 22:56:32.981747061 +0300
+++ zm-1.20.0/src/zm_user.cpp 2005-01-23 23:47:33.140934710 +0300
@@ -106,7 +106,7 @@
User *zmLoadUser( const char *username, const char *password )
char sql[BUFSIZ] = "";
- snprintf( sql, sizeof(sql), "select Username, Password, Stream+0, Events+0, Monitors+0, System+0, MonitorIds from Users where Username = '%s' and Password = password('%s') and Enabled = 1", username, password );
+ snprintf( sql, sizeof(sql), "select Username, Password, Enabled, Stream+0, Events+0, Monitors+0, System+0, MonitorIds from Users where Username = '%s' and Password = password('%s') and Enabled = 1", username, password );
if ( mysql_query( &dbconn, sql ) )
@@ -151,7 +151,7 @@
- snprintf( sql, sizeof(sql), "select Username, Password, Stream+0, Events+0, Monitors+0, System+0, MonitorIds from Users where Enabled = 1" );
+ snprintf( sql, sizeof(sql), "select Username, Password, Enabled, Stream+0, Events+0, Monitors+0, System+0, MonitorIds from Users where Enabled = 1" );
@@ -202,7 +202,7 @@
MD5( (unsigned char *)auth_key, strlen(auth_key), md5sum );
auth_md5[0] = '\0';
- for ( int j = 0; j < strlen((const char *)md5sum); j++ )
+ for ( int j = 0; j < MD5_DIGEST_LENGTH; j++ )
sprintf( auth_md5+strlen(auth_md5), "%02x", md5sum[j] );
- [morgans@video ~/downloads> cd to ~/downloads/zm-1.20.0
[morgans@video ~/downloads/zm-1.20.0> patch -p1 <zm_user_patch
patching file src/zm_user.cpp
Hunk #1 FAILED at 106.
Hunk #2 FAILED at 151.
Hunk #3 FAILED at 202.
3 out of 3 hunks FAILED -- saving rejects to file src/zm_user.cpp.rej
[morgans@video ~/downloads/zm-1.20.0> cat src/zm_user.cpp.rej
*** 106,112 ****
--- 106,112 ----
*** 151,157 ****
--- 151,157 ----
*** 202,208 ****
auth_md5[0] = '\0';
--- 202,208 ----
auth_md5[0] = '\0';
Skydiver
Oops! I have understood in what a problem. At the publication of a patch here all Tab characters were replaced on 8xSpace. Try to download a file with a patch: http://oskin.ru/zm/zm-1.20.0-authfix.patch
Yes, it so. I have checked up it and have found an error in zms.cpp:
WARNING!!! Don't use this patch by copy&paste. Download full patch from http://oskin.ru/zm/zm-1.20.0-authfix.patch
Or use rpm packages:
ftp://oskin.ru/pub/linux/RedHat/MyRPMS/ ... C3.src.rpm
ftp://oskin.ru/pub/linux/RedHat/MyRPMS/ ... 3.i386.rpm
--- zm-1.20.0/src/zms.cpp.orig 2005-01-27 11:20:04.876854026 +0300
+++ zm-1.20.0/src/zms.cpp 2005-01-27 11:21:19.813798099 +0300
@@ -141,12 +141,15 @@
user = zmLoadAuthUser( auth );
- if ( !user )
+ if ( (bool)config.Item( ZM_OPT_USE_AUTH ) )
- Error(( "Unable to authenticate user" ));
- return( -1 );
+ if ( !user )
+ Error(( "Unable to authenticate user" ));
+ return( -1 );
+ ValidateAccess( user, id );
- ValidateAccess( user, id );
setbuf( stdout, 0 );
if ( nph )
- zoneminder
- Site Admin
- Contact:
1.20.1?
I notice its not on the download site yet. How long before it is?
prefer to not do the patch if it is going to happen soon.
TIA
Tnt
TIA
Tnt
- zoneminder
- Site Admin
- Contact:
