I just want someone who can help me or explain me exactly where is my problem on the configuration zoneminder
I'm professionnal of asterisk solution VoIP but not on the Zoneminder and I really want to try to connecte my asterisk and zoneminder but unfortunatly is't more hard as I was thinking
Todays my zoneminder is running but I cannot see any camera on the screen : I'll explain to you more and I hope you can help me little bit thank you.
I have 2 caméra WVC2300 and WVC210 and this camera work if I'm using the link http access direct by the server WEB inside on the camera so this is the link I use to see directly on the firefox
http://user:password@IP_Server/img/video.mjpeg this is for both of the camera WVC210 ans also WVC2300 and is working ok!
so that is normal for the moment ok and I prefer to configure my camera WVC2300 on RTSP protocol to using on zoneminder .
So I catch the signal video directly on VLC I only do that just to be sure the RTSP is working and It's ok I can see direct on VLC with the WVC2300 but the RTSP for the WVC210 it is not working because I didn't find the right path beacause is not the same as below
rtsp://192.168.1.100:554/img/video.MPEG-4%20SP this work on VLC for WVC2300 but not with WVC210.
OK let talk now onn my zoneminder problem
so this is the problem I put both of the camera on zoneminder and I can't see any flux video on the creen, I tried both of the config one with HTTP and the other one with RTSP and same problem no video???? Zoneminder writting running I can stop and start without problem so everything looks like correct but can not find the video flux on both camera
this is the configuration on my 2 camera
screen - WVC230 RTST
* General
Name WVC2300
Source Type remote
Fonction monitor
Activity yes stick
i/s maximum 30.00
Alarm Maximum FPS nothing
Reference Image Blend %ge 7
* Source
Remote Protocol RTSP
Remote Method RTP/RTSP
Remote Host Name 192.168.1.100
Remote Host Port 554
Remote Host Path img/video.MPEG-4%20SP
Remote Image Colours 24bit
Larg. capture (pixels) 320
Haut. capture (pixels) 240
Preserve Aspect Ratio no stick
screen - WVC210 HTTP
* General
Name WVC210
Source Type remote
Fonction monitor
Activity yes stick
i/s maximum 30.00
* Source
Remote Protocol HTTP
Remote Method SIMPLE
Remote Host Name 192.168.1.101
Remote Host Port 80
Remote Host Path img/video.mjpeg
Nom Fonction Source Evènts Heure Jour Semaine Mois Archived Zones Order Marque
0 0 0 0 0 0 1
WVC2300 Monitor 192.168.1.205 0 0 0 0 0 0 1 UpDown
WVC210 Monitor 192.168.1.204 0 0 0 0 0 0 0 UpDown
and Nothing work so if someone can help me to explain me exactly where is my problem it'll be great thank you a lot
ps: sorry for my bad english I try to do the best as I can
Cordialy
Diablo
I really need some Help please thank you
Hi KeithB
Thank to answer my post, but unfortunatly it's the same problem I already tried to put that on the field
this is for the HTTP caméra WVC210
Remote Host Name toto:toto@192.168.1.100
this is for the RTSP caméra WVC2300
Remote Host Name toto:toto@192.168.1.101
after on the zoneminder
0 0 0 0 0 0 0
WVC2300 Monitor 192.168.1.101 0 0 0 0 0 0 0 UpDown "This line is ORANGE "
WVC210 Monitor 192.168.1.100 0 0 0 0 0 0 0 UpDown "This line is ORANGE "
what doesn't mean exactly the color beetween orange and red on the line on all camera does this means when we don't have acces on the flux video on the camera if I don't put the login and password ????
0 0 0 0 0 0 0
HI KeithB
Yes when I change to reccord it's comming on green but
WVC2300 Record 192.168.1.205 0 0 0 0 0 0 0 UpDown "On this line the function and the source are green
WVC210 Record 192.168.1.204 1 1 1 1 1 0 0 UpDown "On this line the function and the source are green"
I Have a question for you , do you think it's better to use all my camera with protocol RTSP it's mutch better than HTTP for you ?
Sorry maybe my question look like stupid for some people but I'm not trong at all on video I'm just good on asterisk so I can help you on asterisk if you want one days this is why I realy want to know zoneminder it's for connect both one the application
so ok when everything are green it means working but when I I click on the
Cycle / Montage
I get a Blank page like this without video
Montage Scale:Actuel Layout Default
and nothing I'm complétly lost I try everithing install 3 others zoneminder everytime it's same I 'm sure I must forget something what ?? don't know yet hope you or someone can help me thank for answer all time KeithB
Cycle / Montage
is someone can may answer me or not for my problem
I still have the same problem
no video
i dont have experience with those camera types, however.
your problem could be as simple as the web browser that you use. if the sources are green, try Firefox instead of IE.
if that doesn't solve your problem...
try without passwords ( in the cam setup & zoneminder ) and...
turn off all but one cam, then in the buffer section:
"image buffer size" to at least 60 ad the "pre event image count" to 10
if you get video, you can go from there.
IE can be used but Firefox works outta the box so one less variable to over come while setting up.
i have a hard time getting GOOD results from internet explorer on a working system. the again i hate IE so never spent more that a few mins on it.
don't give up you'll get it.
Thank River
just for some information I already use all the time firefox 3 , I also hate IE so about the browser i think it's ok .
yesterday I found one post this one http://www.zoneminder.com/wiki/index.php/Linksys and I change the path of both camera
For HTTP
# Remote Host Name: user:password@ip.ad.dr.ess
# Remote Host Path: img/mjpeg.jpg
and I also try this but not working ??
For HTTP
# Remote Host Path: img/snapshot.cgi?size=3&quality=1
and only on one camera WVC210 I get the video but not all time this is very strange maybe it's the Path it's not setting propely what do you think ????
How Can I get the rigth path for both camera I already check the RTFM on camera and nothing writting but on VLC I get for RTSP on the WVC2300 this is the path and it work very weel
rtsp://192.168.1.205:8500/img/video.MPEG-4%20SP
for WVC210 I did not find for RTSP but for HTTP no problem
on the link I send you it's writting "What doesnt work"
* img/video.mjpeg (and other similar urls). Generally barfs on zm_remote_camera_http.cpp:134, and I cant be bothered debugging it. "
This is the problem because it's was exactly the path I use on firefox and work with VLC also but if I understand it doesn't work on Zoneminder .
http://IP_CAM/img/video.mjpeg
so if I use
I get for the first time some video but only if I click on the button cycle not on the montage or on the name of camera this doesn't work do you have a ide ???
I will try to take of the login and password on camera juste to be sure thank for the answer
For HTTP
For HTTP
so if I use
Hi Diablo,
Did you have some results, with your cisco cams?
I am going to buy 15 PVC2300 for a network CCTV solution.
I work also with asterisk and zoneMinder, i am interrested in your idea to use them together.
If you want we can speak in french , send me an email to dguevara@nxtview.com
Best regards
Best regards
