Same image at multiple channels
SoyGabriel
Post by SoyGabriel »
Hello forum, I am Gabriel, Buenos Aires, Argentina
My english is very bad, I used the google translator, sorry for semantic errors, so sorry
We have 14 cameras, one of them with Pelco D controls. We know that all cameras work well as they were working with a system that we inherited, under Windows XP.
Since we are migrating all our platform to Linux, is that we chose for our server ZoneMinder video.
We have installed ZoneMinder on Ubuntu 1.24.2 Server 10.04 recently
From the moment we started the installation, I am visiting and going through this forum and gradually we were able to run ZoneMinder.
Our system shows the following characteristics
: ~ $ lspci | grep video
03:0 C.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
03:0 d.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
03:0 E.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
03:0 f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
: ~ $ ls-la / dev / video *
crw-rw-rw-+ 1 root video 81, 0 28/07/2010 12:53 / dev/video0
crw-rw-rw-+ 1 root video 81, 3 28/07/2010 12:53 / dev/video1
crw-rw-rw-+ 1 root video 81, 5 28/07/2010 12:53 / dev/video2
crw-rw-rw-+ 1 root video 81, 7 28/07/2010 12:53 / dev/video3
: ~ $ vi / etc / modprobe.d / bttv.conf
# I2c
alias char-major-89 i2c-dev
i2c_debug options i2c-core = 1
options i2c-little-bit bit_test = 1
# Bttv
alias char-major-81 videodev
alias char-major-81 bttv
gbuffers options bttv card = 16 tuner = 24,24,24,24,24,24,24,24 = 131,131,131,131,131,131,131,131 radio = 0 lumafilter = 1 Combfilter chroma_agc = 1 = 1
options tuner debug = 1
In several forums I read that we recommend to first with xawtv or tvtime, and above all, first of all run "xawtv-hwscan, we showed the following:
:~$ sudo xawtv -hwscan
This is xawtv-3.95.dfsg.1, running on Linux/i686 (2.6.32-24-generic-pae)
looking for available devices
port 63-78
    type : Xvideo, image scaler
    name : Radeon Textured Video
/dev/video0: OK                         [ -device /dev/video0 ]
    type : v4l2
    name : BT878 video (Leadtek WinFast 20
    flags: overlay capture
/dev/video1: OK                         [ -device /dev/video1 ]
    type : v4l2
    name : BT878 video (Geovision GV-800(S
/dev/video2: OK                         [ -device /dev/video2 ]
    type : v4l2
    name : BT878 video (Terratec TerraTV+
/dev/video3: OK                         [ -device /dev/video3 ]
    type : v4l2
    name : BT878 video (Tibet Systems 'Pro
We're using for almost two weeks and slowly we are going to configure our measure, and this is where we encountered problems, it is now their story.
We had no problems in setting up and clearly visible under the following configuration:
/dev/video0 Channel 0 ==> Perfect
/dev/video1 Channel 0 ==> Perfect
/dev/video2 Channel 0 ==> Perfect
/dev/video3 Channel 0 ==> Perfect
but ...
/dev/video1 Channel 1 ==> Repeat image /dev/video1 Channel 0, is perfect, but repeats the image
/dev/video1 Channel 2 ==> Image Repeat /dev/video1 Channel 0, is perfect, but repeats the image
/dev/video1 Channel 3 ==> Image Repeat /dev/video1 Channel 0, is perfect, but repeats the image
/dev/video3 Channel 1 ==> Repeat image /dev/video3 Channel 0, is perfect, but repeats the image
/dev/video3 Channel 2 ==> Image Repeat /dev/video3 Channel 0, is perfect, but repeats the image
/dev/video3 Channel 3 ==> Image Repeat /dev/video3 Channel 0, is perfect, but repeats the image
/dev/video3 Channel 8 ==> Image Repeat /dev/video3 Channel 0, is perfect, but repeats the image
/dev/video3 Channel 9 ==> Image Repeat /dev/video3 Channel 0, is perfect, but repeats the image
/dev/video3 Channel 10 ==> Image Repeat /dev/video3 Channel 0, is perfect, but repeats the image
/dev/video3 Channel 11 ==> Image Repeat /dev/video3 Channel 0, is perfect, but repeats the image
I mean ... I can not lift the rest of the channels, only channels 0.
I am aware that there is much written in the forums, but for days I'm traveling and despite having done hundreds of tests, are still able to lift the rest of the channels, either with ZonMinder with xawtv or tvtime.
Any ideas?
Remember that a forum can guide me?
Of course, many thanks for any help you can give me!!
For the creators of ZoneMinder is Wonderful, Congratulations!
SoyGabriel
kingofkya
Post by kingofkya »
In the zm option page
under config
find "V4L_MULTI_BUFFER"
un check the box
Also this is incorrect:
should be
or
tuner = 131,131,131,131,131,131,131,131
SoyGabriel
kingofkya wrote:In the zm option page
under config
un check the box
should be
or
Hi kingofkya
than you for your reply
Yes. right is:
options bttv    gbuffers=16    card=131,131,131,131,131,131,131,131    tuner=24,24,24,24,24,24,24,24
radio=0    lumafilter=1    Combfilter=1    chroma_agc=1
Y "V4L_MULTI_BUFFER" is disabled
And do not get results ..., still showing the same images are repeated from
/dev/video1 channel = 0
and
/dev/video3 channel = 0
Actually, the picture I get is very good, the problem is that I can not get to show me the rest of the channels
Soy Gabriel
bb99
Post by bb99 »
If disabling multi buffer didn't work then it's back to basics. All cameras on a single chip (you have four) must be set to the same type (NTSC, PAL), resolution (i.e. 320x240 for now), and the same palette(i.e. RGB, I really would like you to set yours to grayscale for now). Your maximum frame rate should be set to 4-5 fps for all cameras (30/4=7.5 minus 1 to 2 frames per camera for channel switching). CAPTURES_PER_FRAME will probably need to be a value of 2 or 3 eventually which will lower the frame rate again so try a maximum of 3 to begin with. Disconnect all cameras and connect one working camera to a card connection and discover that device channel number by trying the possible combinations until it works (video0, channel0, video0, channel1, etc). Disconnect that camera (you can label the connection with it's source values if you want) and connect it to another connection (still only one camera) and do the same until you've discovered all the connections. Now start to connect more cameras, one at a time, keeping in mind the above settings and that the warm up frames (25) will take 9 seconds for the camera to show a display, so give ZM some time in between changes.
SoyGabriel
bb99 wrote:If disabling multi buffer didn't work then it's back to basics. All cameras on a single chip (you have four) must be set to the same type (NTSC, PAL), resolution (i.e. 320x240 for now), and the same palette(i.e. RGB, I really would like you to set yours to grayscale for now). Your maximum frame rate should be set to 4-5 fps for all cameras (30/4=7.5 minus 1 to 2 frames per camera for channel switching). CAPTURES_PER_FRAME will probably need to be a value of 2 or 3 eventually which will lower the frame rate again so try a maximum of 3 to begin with. Disconnect all cameras and connect one working camera to a card connection and discover that device channel number by trying the possible combinations until it works (video0, channel0, video0, channel1, etc). Disconnect that camera (you can label the connection with it's source values if you want) and connect it to another connection (still only one camera) and do the same until you've discovered all the connections. Now start to connect more cameras, one at a time, keeping in mind the above settings and that the warm up frames (25) will take 9 seconds for the camera to show a display, so give ZM some time in between changes.
Hi bb99:
Thank you very much for your reply bb99. In the morning, first thing, try to do this you've recommended. Then comment as I have been in luck. Again, thank you very much
SoyGabriel
Hi bb99:
Before testing recommended by bb99, a colleague told me that the problem we have is that the card is bad or not selected is correct.
The drawback is that the server will inherit armed and really have no idea that plaque is, pull it out and look for some feature that will let us look at least its manufacturer, but no luck.
The only data we could get the chips are:
Conexant Fusion 878A
Someone could tell me how I can detect that board is really?
Of course, thank you very much
SoyGabriel
ps: could achieve maximum number of cameras, making the following "option":
options bttv  gbuffers=32 card=34,157,25,131 tuner=4,4,4,4 radio=0 chroma_agc=1 combfilter=2 full_luma_range=1 coring=1 autoload=0
I got pictures of 4 different cameras in canals
/dev/video0 0
/dev/video1 0
/dev/video2 0
/dev/video3 0
and then repeated on other channels
SoyGabriel
SoyGabriel wrote:
Hi bb99:
SoyGabriel
/dev/video0 0
/dev/video1 0
/dev/video2 0
/dev/video3 0
Please!!!!, Any idea???
thanks
SoyGabriel
bb99
Post by bb99 »
Did you give my suggestions a try?
Take a look at these and post if either is correct.
http://www.zoneminder.com/forums/viewto ... usion+878a
Or search the forums for "Conexant fusion 878a", several pictures are posted along with the card type settings.
My guess: card=131,131,131,131 tuner=4,4,4,4
SoyGabriel
bb99 wrote:Did you give my suggestions a try?
Hello bb99
If the plate is showing the first image:
http://www.zoneminder.com/forums/viewtopic.php?t=14295&highlight=conexant+fusion+878a
If I did, but the same problem persists.
The problem is that I selected cards only allow four channels at most.
I tested with the card 133 and 132, and now I will try the 131, as recommended.
With the cards 133 and 132 can not get image to show me any image on any channel, nothing.
With the card 131, shows the same image in some of the channels, in others, nothing ..., but now I will return to the test as it's recommend you
Thanks!
bb99
Post by bb99 »
Did you notice the odd ball channel number system used by that card:
From the wiki (Kodichrome 4400):
modprobe bttv gbuffers=16 card=133,132,133,133
or
edit your modprobe.conf to include
options bttv gbuffers=16 card=133,132,133,133
requires a 2.6.12 kernel but fully supported in a 2.6.13
I tried and failed on the 2.6.12 but succeeded on the 2.6.13
When using all 16 channels plug the additional BNC's onto the headers bearing in mind the first 4 are on the card. but the order of the channels is 1,2,3,4,9,8,5,4,13,12,11,10,15,14,7,6
Or from the post:
options bttv card=133,132,133,133
Setup in zm:
/dev/video0(0)
/dev/video1(1)
/dev/video2(2)
/dev/video3(3)
/dev/video0(4)
/dev/video1(5)
You can assign video channels 0 to 15 to any of the four devices (video0 to video3) as you see fit:
/dev/video0 (0 to 15)
/dev/video1 (0 to 15)
Of coarse it's best to not load up to many channels on one device.
See kodicom 4400 for reference.
Hope this helps.
SoyGabriel
We continue with the same problem
Well, the only cards that gave me the 16 channels I need, was as follows:
Tibet Systems' Progress DVR CS16 (card = 131), so definitely, we confirm that this is the card we have in place.
The cards 133 and 132, never showed us any image
Configure the bttv.conf, as follows:
options i2c-algo-bit bit_test=1
options bttv gbuffers=16 card=131,131,131,131 tuner=4,4,4,4
We started ZoneMinder, assuming this configuration of channels:
cam01:/dev/video0 0
cam02:/dev/video0 1
cam03:/dev/video0 2
cam04:/dev/video0 3
cam05:/dev/video1 0
cam06:/dev/video1 1
cam07:/dev/video1 2
cam08:/dev/video1 3
cam09:/dev/video2 0
cam10:/dev/video2 1
cam11:/dev/video2 2
cam12:/dev/video2 3
cam13:/dev/video3 0
cam14:/dev/video3 1
cam15:/dev/video3 2
cam16:/dev/video3 3
The result we obtained was repeated on every screen, the image of /dev/video3 channel=0, and if we disconnect from /dev/video3 channel=0, all images are in black
Again, I made the recommended bb99 and continue with the same problem.
I discuss what we do:
Disconnect all cables from the card.
We started to try connecting the wires one at a single connection to the card, but only get picture when connecting to /dev/video3 channel=0, but never could get two different images.
Traveling through the forum, found suggestion to try xawtv, installed:
aptitude install xawtv
and then execute
sudo xawtv -c /dev/video0
and only get a picture when connecting a camera in the position that corresponds to /dev/video3 channel=0 and this picture is repeated in the channels 1,2,3,8,9,10 and 11, but again, no two different images at the same time.
To discard any extra problem, again put up a hard drive with Windows XP with a similar system ZoneMinder and working properly, perfect..., but we insist that we want to migrate to linux server images please...., , HELP ME!!!!!!!!!!!...., please
SoyGabriel
bb99
Post by bb99 »
Ok, so your original card value of 131 works so now change the tuner back to it's original value of 24 (tuner=24,24,24,24) and post results
SoyGabriel
bb99 wrote:Ok, so your original card value of 131 works so now change the tuner back to it's original value of 24 (tuner=24,24,24,24) and post results
Hello bb99:
We did what you suggested and the result is not good...., I think
Changes in options:
From
card = 4,4,4,4
to:
card = 24,24,24,24
reboot the computer and the first thing we see is that it shows many errors before they reach the login.
Once we enter, we notice that we only have:
/dev/video0
and disappeared:
/dev/video1
/dev/video2
/dev/video3
Anyway we entered the ZonMinder, and we see that it keeps repeating the same image but only in the following channels:
video0/channel0
video0/channel1
video0/channel2
video0/channel3
It was hoped this?
SoyGabriel
bb99
Post by bb99 »
Should have been "tuner=24,24,24,24" not "card=24,24,24,24" and I had thought your original values were correct but formatted incorrectly.
SoyGabriel
bb99 wrote:Should have been "tuner=24,24,24,24" not "card=24,24,24,24" and I had thought your original values were correct but formatted incorrectly.
Sorry bb99:
right is:
Changes in options:
From
to
card=131,131,131,131 tuner=24,24,24,24
/dev/video0
and disappeared:
/dev/video1
/dev/video2
/dev/video3
video0/channel0
video0/channel1
video0/channel2
video0/channel3
It was hoped this?
Again, thank you
SoyGabriel
