I have a problem no create dev/video2 only dev/video0(usb) dev/video1(work perfec en zm)
eduardo@eduardo-desktop:~$ lspci | grep video
07:00.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
no dev/video2
just a guess
Are the settings for all three cameras the same? If not try that.
If its in montage where this is happening, from the faq...
You will need to increase the number of allowed connections to use the montage view with more than a small number of cameras. Certain FireFox extensions such as FasterFox may also help to achieve the same result.
To resolve this situation, follow the instructions below:
Enter about:config in the address bar
scroll down to
browser.cache.check_doc_frequency 3
change the 3 to a 1
browser.cache.disk.enable True -> False
network.http.max-connections-per-server -> put a value of 100
network.http.max-persistent-connections-per-proxy -> 100 again
network.http.max-persistent-connections-per-server -> 100 again
scroll down to
change the 3 to a 1
