I have ZM installed and running, and my Microsoft LifeCam Cinema running on Ubuntu 32 bit desktop (works fine in Skype, at /dev/video0)
I cant seem to get it working in ZoneMinder
I have tried several different FPS, Format, and Palette settings
No image is drawn when trying to view the camera
The only time I did get an image to draw was when I used the following settings: 320x200 resolution, Video for Linux V. 1, RGB24 - but the image was completely black and showed Idle/0 FPS
The Lifecam cinema natively runs at 1280x720 so I assumed I needed to use resolutions at the same aspect ratio, I have tried 480x200, 800x450, etc.
And since its widescreen I have tried NTSC and ATSC
I havent been able to find any combination of settings that works.
Does anyone know what I can try?
Thank you
