ZM-1.20.0 Fedoa Core 3 RPM
cordel
Post by cordel »
I just finnished packaging zm for FC3 I think. I used Oskins zminit script and based every thing pretty much on what he done. I need a few brave souls to test it out.:twisted:
PM me if your interested.
Cheers,
Cordel
PS I just built it onto a mini distro of FC3 I'll keep ya posted on how it goes.
I should know if everything is good... or not in 30 minutes :)
cordel
Post by cordel »
Ran into a hitch with the init script. Affaid we'll have to wait for Oskin for his super fine work.
just a bit beyond me at the moment. :cry: or maybe I've been up and awake to long :shock:
I unfortunately have to leave for work so by the time I get back I'll probably be wiped. But I'll tinker somemore when I can.
Cheers,
Cordel
cordel
Post by cordel »
Darn it,
I pretty sure I found the problem. No sleep for me. Be on it as soon as I get back.
Cheers,
Cordel :oops:
cordel
Post by cordel »
Packages for Fedoa Core 3 at
ftp://cordel.no-ip.info/pub/linux/zonem ... Extra-RPMS
All the extras for ZM as well. If there is any missing perl modules let me know and I'll get them built.
Everything seems to work fine on Fedora with no login issues. Try it out and let me know if there is something I need to address.
Cheers,
Cordel
Updated ftp directory
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
cordel
Post by cordel »
Sorry I had reconfigured the FTP server and forgot to add anonymous access. This has now be addressed.
Cordel
madmax
RPM package
Post by madmax »
I installed the FC3 RPM. I noticed that it installs to /usr/lib/zm
How do it access it from the web interface? do I need to copy it to /var/www/html??
cordel
Post by cordel »
No need to copy it any where. Type in the url http://localhost/zm
If you look in /etc/httpd/conf.d/zm.conf is set up as a alis so all your static files are in /usr/lib/zm and all your data is in /var/lib/zm
Cheers,
Cordel
PS the credit goes to Oskin for this.
TheWayne
Post by TheWayne »
I installed the RPM on a fresh system and the only module I needed to get was perl-TimeDate which is required by perl-MailTools .
madmax
Working
Post by madmax »
Ok.. thanks. I got my FC3 zm install working with the RPMs. I now want to play with zmtrigger.pl
but I get:
Can't open config file: No such file or directory at zmtrigger.pl line 45.
do you know where zmtrigger.pl pulls the config file? /etc/zm.conf is correct and updated.
ccvanmarion
SQL error on updating settings
Post by ccvanmarion »
Great rpm, everything is working now but I have one problem left.
When trying to update de settings I get the following error:
You have an error in your SQL syntax near ' Contrast = , Hue = , Colour = where Id = '1'' at line 1
Rest of SQL queries is working fine. I don't know if this problem is related to the rpm version or a common problem.
Anyone with a solution?? :?: .
BTW: The only strange thing with this RPM that I have to switch authorisation to on, because without it, no picture or stream was shown.
Thanks for the RPM :P :P
Koos van Marion
cordel
Post by cordel »
The Steamming issue with no autherazation is fixed in the the next version.
It's on my ftp now as zm-1.20.1-RC1
As for the SQL error it is still present in the the release canidate and to ellaborate this error it shows up from the settings link above the streaming video. confermed
Madmax I'm testing the new version and I do not recieve this error. How would I duplicate it?
What are your settings?
Cordell
madmax
zmtrigger
Post by madmax »
When I try to run zmtrigger, I get the following error. I have the same problem with zmx10.pl
[root@zoneminder bin]# perl zmtrigger.pl
BEGIN failed--compilation aborted at zmtrigger.pl line 73.
cordel
Post by cordel »
Did you install zm-X10? It's on the ftp server as well. Also have you upgraded the database?
It looks like zmtriggers looks to the database to get it's config info. Check the readme for usage of zmtriggers.
Cordel
madmax
zmtrigger.pl
Post by madmax »
Cordel,
Thanks for all of the help. I apparently did not install the X10 rpm. That fixed X10 and triggered events. I still was unable to get zmtrigger.pl to run at all. But, I am happy for now with X10.
cordel
Post by cordel »
Great, Now maybe you can point me in the right dirrection to get started using X10. What do I need to get sarted?
Cheers,
Cordel
