BT878 shows crappy pictures
speedamaster
Post by speedamaster »
I got my bt878 card working in my ClearOS engine....
Now I got a crappy picture quality and I can hardly see the objects.... any idea? Looks like yellow, green waves...
http://www.filefactory.com/file/b0023fe/n/Clipboard01.jpg
trashisfree
Suggestions to try
Post by trashisfree »
settings for each monitor
Tweak the settings till your colors come out better
Monitor-1
Brightness Brightness and Contrast set properly will help some too
Contrast
Hue
Colour Big one for off colors try lower and higher until your colors come out right.
If your camera will do 640*480 instead of 320*240 set that correctly.
Probably need to change shmall and shmax settings
Pre Event Image Count set to 2, so that 2 captures are combined into 1, will clean up noise and improve picture quality.
