From my searching, I understand that Zoneminder used to have a ZM_WEB_MONTAGE setting in its configuration. I never had a need to achieve what I think it did so did not make use of it, but now I have a system with many more cameras and would therefore like to set a default montage scale and layout.
Any chance this feature could be reinstated in the next release?
Thankyou
zm_web_montage
zm_web_montage
Last edited by Jason_Bassett on Thu Aug 19, 2010 10:52 am, edited 1 time in total.
Setting defaults
Hello
I know that the Cycle/Montage view is available still and that I can select Scale and Layout within it. But this does not save my required Scale and Layout.
What I would like it to set the default Scale and Layout for the Montage window, from within the Options area.
That way, when anyone on any machine opens the Montage, it will open with the default Scale and Layout - perhaps even allow a per user setting to allow it to be overridden depending on users preferences.
Jason
Jason
hey guys, old post here. I just upgraded from 1.23 to 1.24 in Ubuntu Server 9.10, and was disappointed to find that the feature to set the size and scale of the montage pop-up has apparently been removed. I really liked this feature, because I had it set up to have little 30% scale sizes of my cameras in a pop-up that was very small, so i could have it sitting in the top left of my screen, to casually keep an eye on things at home from work. Now, it just pops up this monstrosity of a layout.
Why was this removed, and is it possible to manually edit config files to achieve this?
Re: Setting defaults
on the Zoneminder console you can choose options on the top right corner if you have root or admin control. In three tabs for bandwidth: High B/W, Medium B/W and Low B/W there is a setting for WEB_x_DEFAULT_SCALE. You can change it to any percentage scale you prefer it to open on. A user can still change it if they prefer a different scale view. You can also change it on each camera option but that's a pain.Jason_Bassett wrote:Hello
Jason
I do wish it had an option to change how many cameras per row as a default. I cant seem to find that anywhere. The montage default is 3-wide but I prefer 4-wide, since it fits nicely full screen.
