no video--zoneminder waiting for ip
russ
Post by russ »
I'm a newbe to umbutu,apache and zoneminder. However, I've managed to get an web server and ftp server to work, I'm now trying to get zoneminder to work with a usb webcamera. The camera works fine with cheese and xawtv. I am able to take still shots and video using cheese but when I run zoneminder, I end up with a white screen and cam1 (device name) at the top. At the bottom of the camera screen I get a message that says waiting for localhost.This ,of course,is the address in firefox I use to call up zoneminder. I'm using Ubuntu 10.04 . I've fixed the ip address in interfaces and my router.
Can anyone tell me where to start looking for this problem?
Thanks for any help
russ
bb99
Post by bb99 »
Post your source settings; someone will jump in.
russ
no video
Post by russ »
thanks bb99 for replying to my request for help.
i don't know what you mean by posting my source settings but--
i'm using ubuntu 10.04---apache2 2.2.14 and zoneminder 1.24.2.
in looking through my files,i found the following
08/31/10 11:08:41.571189 zmwatch[1647].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/31/10 11:08:51.573579 zmwatch[1647].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/31/10 11:09:01.575975 zmwatch[1647].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/31/10 11:09:11.578323 zmwatch[1647].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/31/10 11:09:21.580886 zmwatch[1647].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
08/31/10 11:09:31.584454 zmwatch[1647].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
also
[Tue Aug 31 11:16:40 2010] [error] [client 192.168.3.1] PHP Warning: session_start(): open(/var/lib/php5/sess_ujatgfs9h3an4j2ejianfrdep7, O_RDWR) failed: Permission denied (13) in /usr/share/zoneminder/index.php on line 77
[Tue Aug 31 11:16:43 2010] [error] [client 192.168.3.1] PHP Warning: Unknown: open(/var/lib/php5/sess_ujatgfs9h3an4j2ejianfrdep7, O_RDWR) failed: Permission denied (13) in Unknown on line 0
[Tue Aug 31 11:16:43 2010] [error] [client 192.168.3.1] PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0
[Tue Aug 31 11:16:50 2010] [error] [client 192.168.3.1] PHP Warning: session_start(): open(/var/lib/php5/sess_ujatgfs9h3an4j2ejianfrdep7, O_RDWR) failed: Permission denied (13) in /usr/share/zoneminder/index.php on line 77, referer: http://honeyman.zapto.org/zm/
[Tue Aug 31 11:16:50 2010] [error] [client 192.168.3.1] PHP Warning: Unknown: open(/var/lib/php5/sess_ujatgfs9h3an4j2ejianfrdep7, O_RDWR) failed: Permission denied (13) in Unknown on line 0, referer: http://honeyman.zapto.org/zm/
[Tue Aug 31 11:16:50 2010] [error] [client 192.168.3.1] PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0, referer: http://honeyman.zapto.org/zm/
can anyone help me with these errors?
thanks
gamesmasta
Post by gamesmasta »
Same issue. I receive camera feed in XawTV. I configured the camera in ZoneMinder but when I go to the Monitor feed I do not see a video. I see at the bottom "Waiting for localhost" and then nothing happens :S
Any common mistake?
