And here are my settings for the moment:
I changed the "Remote method" from "Simple" to "Regexp" and it instantly worked... finally!!Source type: Remote
Remote Protocol: HTTP
Remote Method: Regexp
Remote Host Name: 192.168.1.254
Remote Host Port: 8070
Remote Host Path: /video.mjpg
Capture Width: 320
Capture Height: 240
Then I secured the access to the ZM webpage by changing login credentials, I logged back in with the right codes and... doh... it was no longer working, the "Feed view" was no longer broadcasting the video feed?!
I guess I'll have to reboot/restart my Linux box... see you later with, hopefully, good news!
highmighty
