in "options" --> "paths" I changed DIR_EVENTS from "events" to "/media/[name_of_storage]/events" to outsource the images done by zoneminder on an exteral storage.
When zoneminder performs an "event" I can see the live stream. But when I want to open recorded images or streams nothing happens, although the images are existing on the external storage.
To test i if the standard parameter works, I set the DIR_EVENTS back to "events" and everything is okay.
How can this problem be solved?
Regards
Ray
[SOLVED] Viewing recorded and outsourced streams in Firefox
Ok, after googling a long time I got the advice to create a symlink.
I renamed the folder event in /var/cache/zoneminder/ to event_old,
opened a terminal and wrote:
But the problem is still there. I can't open streams from the external HDD with Firefox.
Regards
Ray
ln -s /media/zone/events /var/cache/zoneminder/
Regards
Ray
that is a nice workaroung. I have the same problem and I looked in the /var/log/messages and it gives this message:
It's a bug in the application code. It expects a relative path to the instalation dir:/usr/share/zoneminder/www/
I will use the workaround until it's fixed.
zms[31136]: ERR [Can't open /usr/share/zoneminder/www//mnt/SmallVille1/recording/1/1064/001-capture.jpg: No such file or directory]
