Android Application
Android Application
I have created an Android application (working on 1.6+) which I currently use to monitor a number of cameras (live streaming or snapshots if on a slow connection) and also control X10 devices (using http://www.heyu.org/ installed on my ZoneMinder server)
At the moment its fully working but quite specific to my own setup, so I wanted to see how much interest there would be if I created a generic ZoneMinder/X10 control application.
I can post some screenshots of the current application if anyones interested.
thanks
Toby
thanks
Toby
Android App
I would be very interested in an android app that let you choose multiple servers and the cameras associated
- Contact:
- Contact:
Any updates on Droid App?
Hey Checking with you on the droid application to see if you have made any updates.
I would be willing to help finish up the coding on it.
Viciguy
<a>323help.com</a>
<a>323help.com</a>
Hi all,
Had not had any notifications back from the forum that there were new posts which was strange, but as I see there's quite a lot of interest I will get on with it and get something so you guys can test it.
@newvisionantenna: at the moment it runs without any modifications on the ZoneMinder server (I'm running v1.24.2)
@ddalton: Good point I think multi server setup will be useful. I am going to try and make it auto-detect the available cameras on the server so you won't need to configure it.
Will try and get something testable for the next week or so.
cheers!
cheers!
- Contact:
Thanks, I'll have to try it out on my G1 and login into my dvd test install. I wish you the best of luck and I'm confident you could turn it into a good marketplace add, maybe a free and paid version?
Hopefully it will work on my G1 since I have it running android 2.2. From the factory it should have only went to 1.5 I believe, but with cyanogen it's possible to update further.
That's amazingly good news...thanks for your dedication..
let us know.
let us know.
