New Skin for 1.24
kylejohnson
Post by kylejohnson »
logray wrote:Wow! Stellar work here. Great job. :P
One thing I noticed is that the control feature does not work with this skin. View full, when I click control, the PTZ icons are not available. :-(
Other than that one "annoyance", this is amazing compared with the original skin !!!!
Thanks for the kind words!
I was able to do some work today and got PTZ controls working (at least with my Axis PTZ 215 camera). Should work identical to how controls work in the classic skin, for now.
Please continue to leave feed back and bugs!
Idling as gnulnx in #zoneminder on freenode. Come say hi!
kylejohnson
Fixed the bandwidth option (again).
If bandwidth is low or medium, you get a snapshot (still) of the monitor
if bandwidth is high, you get a live view of the monitor.
logray
Post by logray »
This is serously cool. I am excited about ZM again... the dull canned interface (albeit workable) was geting me dis-interested.
PAN/TILT works like a charm! (and I noticed the bandwidth options work as well now too...) This is great.
Playing around with the events tab I noticed a few areas of intrest.
1.) The video size while browsing (not the search) is the same resolution as the input, would be cool if it could be scaled down (similar to the live view scaling). Maybe I am missing where to set that option if available.
2.) I noticed looking at the events when scrolling down past the last event - just below the video it shows 26-50, 51-75, forever... (which I suppose "would" be future events) as if though I have events beyond the last event, yet there are no more recorded. I suppose a check could go in to see if this is the last even in the table, and then not scroll down any further?
3.) I can't seem to get the playback to work when I open an event. The "play" is "locked" and the video doesn't playback. It also doesn't allow pause/etc.
kylejohnson
logray wrote:This is serously cool. I am excited about ZM again... the dull canned interface (albeit workable) was geting me dis-interested.
1.) The video size is the same resolution as the input, would be cool if it could be scaled down (similar to the live view scaling). Maybe I am missing where to set that option if available.
Lets see..
1) The 'video size' as in the thumbnail, or when you click on one and it opens in a lightbox for playback? The thumbs should be scaled down to the size of WEB_LIST_THUMB_WIDTH in options.
2) Good point :) I'm testing on a box with tens of thousands of events.
3) You won't be able to play until it is finished loading the snapshots... To the left of "Play", there should be a progress indicator that goes from 1% to 100%. When it reaches 100%, Play should become enabled. If that isn't working on your box, let me know annd I'll check it out. Could take a couple minutes on a slow connection (though pretty fast on a LAN)
logray
Post by logray »
kylejohnson wrote:1) The 'video size' as in the thumbnail, or when you click on one and it opens in a lightbox for playback? The thumbs should be scaled down to the size of WEB_LIST_THUMB_WIDTH in options.
The thumbnail size when browsing (not searching) through events. The web_list_thumb_width works in the orignal interface events list and the thumbs are scaled down to the size I specify. However not in the "new" interface, the thumbs are full video size (in my case 800x600).
kylejohnson wrote:To the left of "Play", there should be a progress indicator that goes from 1% to 100%...If that isn't working on your box, let me know annd I'll check it out. Could take a couple minutes on a slow connection (though pretty fast on a LAN)
I don't see any sort of progress meter to the left of play in the lightbox, only a seemingly "greyed out" (Play) button using Ubuntu 10.04 w/latest FF 3.8.x IIRC. This is on a 100mb LAN.
kylejohnson
I've fixed the fetching of more events to only display the pagemark (x to y) if there is more data to display.
Also, looking at the code for playing back events, and testing on my box, I can't find any problems... Do you have Firebug installed? I have a couple lines of debug in the code so that, if you open the Console of firebug when clicking on an event to watch it, you should see output like
Loading images...
Src: events/7/1634526/001-capture.jpg
pos: 16
path: events/7/1634526/
Getting files...
Got 193 files...
Preloading images...
Preloaded: 1
Preloaded: 2
Preloaded: 3
Preloaded: 4
Preloaded: 5
Preloaded: 6
Preloaded: 7
Can you verify whether or not you are receiving these lines in Firebug's console after clicking on an event (the page where Play is locked)?
logray
Post by logray »
kylejohnson wrote: I've fixed the fetching of more events to only display the pagemark (x to y) if there is more data to display.
Looks fantastic. Noticed another issue this AM, after I create tabs on the dashboard, I'm unable to delete them. Clicking on x in the upper right hand corner of the tab does nothing.
kylejohnson wrote: Can you verify whether or not you are receiving these lines in Firebug's console after clicking on an event (the page where Play is locked)?
Firebug output below... it looks like it just "stalls" after preloading images. Perhaps I am missing a module or plug-in somewhere?
Loading images...
Src: events/5/137/001-capture.jpg
pos: 12
path: events/5/137/
Getting files...
Got 44 files...
logray
Post by logray »
More interesting warnings from firebug when opening a lightbox (view full or view event).
Expected ':' but found ';'. Declaration dropped.
[Break on this error] display;block;
skin.css (line 610)
[Break on this error] }
skin.css (line 611)
Error in parsing value for 'filter'. Declaration dropped.
[Break on this error] .cboxIE #cboxTopLeft{background:transp...TopLeft.png, sizingMethod='scale');}
colorbox.css (line 55)
[Break on this error] .cboxIE #cboxTopCenter{background:tran...pCenter.png, sizingMethod='scale');}
colorbox.css (line 56)
[Break on this error] .cboxIE #cboxTopRight{background:trans...opRight.png, sizingMethod='scale');}
colorbox.css (line 57)
[Break on this error] .cboxIE #cboxBottomLeft{background:tra...tomLeft.png, sizingMethod='scale');}
colorbox.css (line 58)
[Break on this error] .cboxIE #cboxBottomCenter{background:t...mCenter.png, sizingMethod='scale');}
colorbox.css (line 59)
[Break on this error] .cboxIE #cboxBottomRight{background:tr...omRight.png, sizingMethod='scale');}
colorbox.css (line 60)
[Break on this error] .cboxIE #cboxMiddleLeft{background:tra...dleLeft.png, sizingMethod='scale');}
colorbox.css (line 61)
[Break on this error] .cboxIE #cboxMiddleRight{background:tr...leRight.png, sizingMethod='scale');}
colorbox.css (line 62)
[Break on this error] .ui-helper-zfix { width: 100%; height:...pacity: 0; filter:Alpha(Opacity=0); }
jquery...tom.css (line 18)
[Break on this error] .ui-priority-secondary, .ui-widget-con...a(Opacity=70); font-weight: normal; }
jquery...tom.css (line 76)
[Break on this error] .ui-state-disabled, .ui-widget-content...pacity=35); background-image: none; }
jquery...tom.css (line 77)
Unknown property 'border-top-left-radius'. Declaration dropped.
[Break on this error] .ui-corner-tl { -moz-border-radius-top...: 5px; border-top-left-radius: 5px; }
jquery...tom.css (line 274)
Unknown property 'border-top-right-radius'. Declaration dropped.
[Break on this error] .ui-corner-tr { -moz-border-radius-top... 5px; border-top-right-radius: 5px; }
jquery...tom.css (line 275)
Unknown property 'border-bottom-left-radius'. Declaration dropped.
[Break on this error] .ui-corner-bl { -moz-border-radius-bot...px; border-bottom-left-radius: 5px; }
jquery...tom.css (line 276)
Unknown property 'border-bottom-right-radius'. Declaration dropped.
[Break on this error] .ui-corner-br { -moz-border-radius-bot...x; border-bottom-right-radius: 5px; }
jquery...tom.css (line 277)
[Break on this error] .ui-corner-top { -moz-border-radius-to... 5px; border-top-right-radius: 5px; }
jquery...tom.css (line 278)
[Break on this error] .ui-corner-bottom { -moz-border-radius...x; border-bottom-right-radius: 5px; }
jquery...tom.css (line 279)
[Break on this error] .ui-corner-right { -moz-border-radius...x; border-bottom-right-radius: 5px; }
jquery...tom.css (line 280)
[Break on this error] .ui-corner-left { -moz-border-radius-t...px; border-bottom-left-radius: 5px; }
jquery...tom.css (line 281)
Unknown property 'border-radius'. Declaration dropped.
[Break on this error] .ui-corner-all { -moz-border-radius: 5...er-radius: 5px; border-radius: 5px; }
jquery...tom.css (line 282)
[Break on this error] .ui-widget-overlay { background: #aaaa...city: .30;filter:Alpha(Opacity=30); }
jquery...tom.css (line 285)
[Break on this error] .ui-widget-shadow { margin: -8px 0 0 -...px; border-radius: 8px; }/* Resizable
jquery...tom.css (line 286)
Unknown property 'zoom'. Declaration dropped.
[Break on this error] .ui-accordion .ui-accordion-header { c...relative; margin-top: 1px; zoom: 1; }
jquery...tom.css (line 300)
[Break on this error] .ui-accordion .ui-accordion-content { ...flow: auto; display: none; zoom: 1; }
jquery...tom.css (line 306)
[Break on this error] zoom:1;
jquery...tom.css (line 336)
[Break on this error] .ui-button { display: inline-block; po...property removes extra width in IE */
jquery...tom.css (line 345)
[Break on this error] .ui-dialog .ui-dialog-content { border...und: none; overflow: auto; zoom: 1; }
jquery...tom.css (line 385)
[Break on this error] .ui-tabs { position: relative; padding... overflow: auto appear as "fixed") */
jquery...tom.css (line 408)
[Break on this error] filter: mask(); /*must have*/
jquery...tom.css (line 472)
logray
Post by logray »
The problem looks to be from console.js, the post line...
		// close icon: removing the tab on click
		// note: closable tabs gonna be an option in the future - see http://dev.jqueryui.com/ticket/3924
		$('#tabs span.ui-icon').click(function() {
			var index = $('li',$("#tabs")).index($(this).parent());
			$.post("skins/new/includes/updateGroups.php?action=delete&groupName=" + $(this).parent().find('a').text());
			$("#tabs").tabs('remove', index);
A workaround...
mysql> select * from Groups;
| Id | Name     | MonitorIds |
|  1 | local    | 4          |
|  2 | remote   | 5          |
|  3 | blahblah | 5          |
3 rows in set (0.00 sec)
mysql> delete from Groups where Name = 'blahblah';
Query OK, 1 row affected (0.00 sec)
kylejohnson
That's what my post line does - it calls a .php file which just sends a delete query. The problem is registering the click on the X in order to post to the .php file :) Can't seem to get it working right,
newvisionantenna
Post by newvisionantenna »
kylejohnson,
Great work on the skin! Since I've been out of the loop for some time now and not familar with what's going on, can you confirm this skin is good to use in production use?
The reason I ask is that seeing this and other enhancements in the forum make me want to sit down and redo another up to date install dvd with all the best features and addons.
I could take the current Ubuntu and install everything by hand, add whatever the community would like to see, and then post a download that would allow a secure end product for someone to easily install and use. It would take me some time to complete, especially with moving, but I'll find some time to roll this up.
kylejohnson
newvisionantenna wrote:kylejohnson,
Definitely not ready for production yet, though soon. Squashing remaining bugs and adding a few features. However, you could bundle the skin and allow the user to change using the ?skin=skin query string.
kylejohnson
Well I have fixed a bunch of bugs recently, but for the life of me I still can not get the tab-deletion working! Not a show-stopper, but annoying none-the-less.
So this skin is probably nearing a production-ready (v1.0) release... Once I fix authentication. I could use bug reports in the mean time!
logray
Post by logray »
This looks great, except I'm still having two issues.
Thumbnails on events home screen are not resized (they are full resolution).
Opening an event yields no playback option, or loading of frames... (see earlier posts). Perhaps I am missing a plug in?
kylejohnson
logray wrote:This looks great, except I'm still having two issues.
With so many bugs, I overlooked those two!
There are no "plug ins" that are needed for this skin. This happens with every one of your events? Are you definitely using the most recent version of the code? Can anyone else confirm these bugs?
