RPM's for the new ZoneMinder version are now available in the repositories. Installation/upgrade instructions can be found in the wiki. Required perl modules, which are missing in the normal openSuSE distribution, are also in the repositories and get's installed when solving the dependencies.
Short summarize of the upgrade instructions:
- To upgrade your current ZoneMinder RPM install, just stop ZoneMinder, install the new package and run zm_database_init which will the automatic call the original zm database upgrade script after path checking to the db scripts. (If your path in the config file is wrong zm_database_init will auto correct the path. all you have to do is to answer the question for that with "y" or "yes"). After that start ZoneMinder by typing "rczm start" and all is done.
- if you just want to update the database the traditional ZoneMinder way (it's recommended to use the wrapper zm_database_init script), edit /etc/zm.conf and change the version to the the new one (1.24.1) and check that ZM_PATH_BUILD is set to /srv/www/htdocs/zm. Then run "zmupdate.pl" and remove the lock file "rm -f /srv/www/htdocs/zm/lock" and start ZoneMinder.
openSuSE 11.0:
http://liquid-co.de/pub/suse/repositori ... 24.1/11.0/
openSuSE 11.0:
openSuSE 11.1:
http://liquid-co.de/pub/suse/repositori ... 24.1/11.1/
You can also try to use the one click install feature:
And for the MP version:
Note: You can also install ZoneMinder (non MP) version from the openSuSE Build Service http://download.opensuse.org/repositori ... x:/stable/ so that you can find version for factory there.
If you find some bugs please report this in the forums and mention that you are using the RPM's
Note: This time I couldn't test it completely because the test system is down and I have no cams here at the moment, the only thing I can ensure is that it installs/upgrades properly If you find some bugs or have problems especially with mootools (I've upgraded to the latest version) report back here.
Have a lot of Fun
Dirk
